-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   Default setting for AC (http://forums.pelicanparts.com/showthread.php?t=888443)
GSpreeman 10-25-2015 04:54 AM
I would like the AC to be off when I turn on the car. I tried to turn it off and then set the user setting, (the little button by the drivers door threshold), but no luck. Any clues?
jwetering 10-26-2015 09:43 PM
Mine mostly starts up in the last position I left it in. I almost always have the AC turned off, but occasionally the system will start up on its own when I start the car.
It's kind of a bizarre hit and miss.
firstorbit84 10-29-2015 06:33 AM
The button by the driver's door is only for seat settings. Mine usually stays in the same setting it was when I turn the car off
Raven 911 10-29-2015 12:19 PM
Yes mine also starts in the settings it was left in ,,,,,I don,t believe you can change this .....;)
