Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Default setting for AC
I would like the AC to be off when I turn on the car. I tried to turn it off and then set the user setting, (the little button by the drivers door threshold), but no luck. Any clues?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 10-25-2015, 04:54 AM
jwetering's Avatar
Mine mostly starts up in the last position I left it in. I almost always have the AC turned off, but occasionally the system will start up on its own when I start the car.
It's kind of a bizarre hit and miss.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 10-26-2015, 09:43 PM
The button by the driver's door is only for seat settings. Mine usually stays in the same setting it was when I turn the car off
Check out my car blog: https://www.youtube.com/channel/UCrCfzKXYAgfwgZPrQ8KYrGw
Old 10-29-2015, 06:33 AM
Retired Action Man
Raven 911's Avatar
Yes mine also starts in the settings it was left in ,,,,,I don,t believe you can change this .....
Old 10-29-2015, 12:19 PM
