Chilly starter
Last winter the starter on my 03 C4S daily driver was, at times,a little finicky when ambient temp was down to about 45 degrees or lower. A couple good depressions of the clutch pedal and she would turn over as strong as ever. Come spring time the gremlin was gone and I had completely forgotten about it. Well, guess what? It's back.
Battery is fresh and fully charged and all electrical systems appear perfectly normal otherwise. Has anyone heard of a clutch pedal switch being temperamental to cold temps? Any other thoughts ?? Thanks, Paul |
Make a jumper to connect the two wires on the clutch switch and see if the problem goes away. Note the cruise may not work if you do this.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
I've had the same issue the last two winters and suspected the clutch switch. When it started getter cold this year and the problem returned I ordered a new switch, installed it, and have not had the problem since.
