-   Porsche Autocross and Track Racing (http://forums.pelicanparts.com/forumdisplay.php?f=26)
-   -   Tell me about your DL-90 Data Logger (http://forums.pelicanparts.com/showthread.php?t=146954)
jluetjen 02-04-2004 03:30 PM
Greg;
If I were you I'd go for a positive mechanical attachment to plate, and then make sure that the plate has a safety strap holding it tight. Can your set-up withstand a solid 30-40G hit? A simple test would be to apply a force equal to 30-40x the pieces' weight against them and see if they push off. If they don't hold, you're liable to have all of that equipiment turn into projectiles. The worst case would be a hit on to left front of the car in which case these projectiles would be aimed at your head.
http://www.pelicanparts.com/support/smileys/spankA.gif
rs911t 02-04-2004 03:46 PM
Good points to stress, all.
The plate also has a nut/washer keeping it attached to the mount, though you can't see it in the picture. On the track the tripod head is bolted to the harness truss (the picture is a test rig in another car) or to a rollbar via a I/O port mount.
Also, I'm not using "normal" velco, rather a plastic 3M material that works on the same principle. I've no doubt it'd stay put in an accident, given how hard it is to remove the DL90 from the plate afterwards!
The camcorder isn't bouncing around on the floor. It's strapped to a seat and/or sitting in a seat/door pocket.
cstreit 02-04-2004 04:28 PM
The DL-90 only weighs a few ounces too. I've got L brackets in the side of mine, those are held to the roll bar with hefty hose clamps. Keeps the DL-90 secure and more in tune to car movement.
304065 02-04-2004 06:13 PM
http://forums.pelicanparts.com/uploa...1075947160.gif
Anyone care to comment on this? What should it look like?
cstreit 02-04-2004 07:07 PM
John,
Looks familiar but you may be giving up some on the left turns. Mine look the same in that respect.
One contructive criticism: The peak in the top middle means that you can also get on the gas a bit earlier... Mine generally have a flatter top, meaning that while I am in heavy corner loads, I am also accellerating hard as well. The peak in the top center shows less accelleration under corner loads.
carnut169 02-04-2004 08:21 PM
Just checked back...
here is the web site:
http://www.aim-sportline.com/
I use the MyChron3 Gold XG & it is sweet....
cstreit 02-04-2004 08:28 PM
Here's one of mine from a fast, but not so challenging track:
You can see that while I pull just over 1.2 G's on the let turns, I'm pulling over 1.3-1.4 on the rights... Pretty common since most tracks run clockwise, but notice the flat top.
http://forums.pelicanparts.com/uploa...1075955257.jpg
NicolasW 02-05-2004 04:04 AM
Whoa! Very sweet...don't mean to hijack the thread...but can you tell us more? A couple years back (5 years) I had a MyChron2 in my 944 Turbo and it was great for lap timing, oil and water temp...but that's about it.
Just saw the MXL which is akin to the Motec Dash, albiet cheaper.
jluetjen 02-05-2004 04:42 AM
Chris;
While trying to visuallize what the data means in the real world, I guess I can make a couple of observation which might be helpful -- and then again -- maybe not.
http://forums.pelicanparts.com/uploa...1075984579.jpg
* It seems like your data points are fairly tightly grouped which would I suspect suggest that you are being pretty consistent. That is a key skill and not always accomplished.
* If you look at the area under the arms of the "T", you can see that there are data points there which would suggest that the car can operate in that area. But there are fairly few data points in that area. Since those regions represent the transition from maximum braking to maximum turning (and vice versa), it would seem to be situations where you are not maximizing the use of the car's handling. Instead in most cases you have reduced your braking to .4 G's, but you are not using any of the turning traction that may be available. It might be an area to pick up some "free" time on the track.
Interestingly, John seems to have more points out there (relatively speaking) then you do.
Now I can also picture the data being skewed by the track geography, but still the fact that there are some points out there suggests that you went there occasionally, just not as much as you could. The image that comes to mind is the thread that you posted a couple of weeks ago about guys racing by coasting down a curvey road.
Caveat -- Having said that, I've never had my driving tracked by instrumentation before, so I can't say that I know what's involved in going into that area of the traction circle.
304065 02-05-2004 06:12 AM
Good commentary here, thanks!
Chris, I see what you are saying, the "peak" at the center means that I am waiting until lateral gs come back close to zero before getting on the throttle-- pickup the throttle earlier and there should be a straight line all the way from the edge of the plot to the peak of acceleration, the inverse of what's on the other side.
Hey, that looks like Road America! (Throttle, zzz, brake, turn, repeat). I agree with John, very very consistent!
John, thanks for pointing that out, this is the classic "friction circle" where you want to drive around the edges of the circle at the limit at all times-- max accel, then max braking, combination of brake/corner, max cornering, then combination of cornering/acceleration to the limit. I guess the ideal one would look like this:
http://forums.pelicanparts.com/uploa...1075990250.gif
jpachard 02-05-2004 06:33 AM
John, Have you used the USB adapter with success?
Cheers, James
304065 02-05-2004 06:35 AM
James, no. I use serial. Your question was whether it could be converted, I know it can, but I don't know whether the software would recognize it.
You might email the developers and ask if they have a USB version in beta. Seems to me that RS-232 is going the way of the dodo. . .
APKhaos 02-05-2004 10:31 AM
Interesting discussion about the G Circle data.
Have to admit I've never really looked at this data critically, but you guys make some good points. Pulled a recent run from VIR, which is a longer track with some fairly technical sections. Not nearly as technical as Mid Ohio or Summit Point. This is what I got.
http://forums.pelicanparts.com/uploa...1076005875.jpg
I guess it looks a little more like a triangle than a cross, although the cross distribution is still dominant. What do your experienced eyes see here? Kinda like a racer's Rohrschach [sp?] test.
cstreit 02-05-2004 11:12 AM
Jleutjen,
THose areas that you have highlighted would be filled if I was doing a lot of trailbraking, which I don't. You would have to be experiencing sideways force while under braking. If you look at the graph in a FWD car, it almost looks upside down to the 911.
However I to John Cramers comment, you can also look at the total G's on a graph and find out if you are just "coasting" in certain places. This doesn't mean that it's particularly bad, in fact it occurs at every turn in when you transition off the brakes and onto the throttle, but haven't quite turned in yet. THe key is to minimze this.
John, it IS Road America.
rs911t 02-05-2004 11:23 AM
I agree Tony. Really interesting thoughts.
At DE events they speak to "managing the tire patch", but now I think they should do more talking. It seems to me the G-circle chart is showing exactly how well the driver does managing the patch. If you have empty space to the left and right of the verticle you're squandering traction. Either trail brake deeper or get back on the throttle sooner.
Cool stuff.
jluetjen 02-05-2004 12:57 PM
Chris;
Actually I didn't want to use the Trailbraking word. The concept should be more of trailing off of the brakes as you feed in steering. Picture a string tied to the rim of the steering wheel and the brake pedal. As you start to turn the wheel, you let up on the brake proportionately.
This is where I would say the advice to the novice would be significantly different then the advice to someone who has spent quite a lot of time pounding around a track in anger.
Rule 1 to the novice: Break in a straight line.
Rule 2 to the experienced racer: Ignore rule 1.
The fact that there are points out there (Note I can see one at -.8 lateral and -.4 longitudinal) proves that the car has grip out there. The trick is being able to use it. If you can use it, I guarantee you that you'll make up a good 20 to 30 feet of track per lap in that corner alone on someone who isn't. It may not be comfortable at first, but it is the secret to being fast. It may also require some careful tuning of the chassis to make the car comfortable in that realm. I would start with the shocks if it were me.
You might also want to go back to the data and identify where on the track you were getting the points under the arms of the T. What is it about those corners (or laps) that let you take the car into that zone?
As Greg mentioned, you need to keep the car on the envelope in order to be fast. A T shaped graph would be perfect for a DE'er. But if you want to make it to the front of an SCCA National, you'll need to be on the envelope.
I've found karting to be a great place to practice this technique since (at least in the rental karts) the brakes only work on the rear axle. So they don't like to be agressively trail braked any more then a 911 does. But in order to go really fast, you need to be able to keep them on the edge of the envelope -- just like the 911 or any or race car.
cstreit 02-05-2004 01:58 PM
JOhn...
All good points... I'll take a look at where I'm getting those values... Could be something special about certain corners where I am doing it... OTOH some corners you just DON'T trailbrake (off cambers for instance) because it's such a fine line between that and looping it, it's not worth the risk. :)
jluetjen 02-05-2004 02:07 PM
Agreed. It's a judgment call.
APKhaos 02-05-2004 02:57 PM
I still trying to figure this out, but trying to correlate these 'under the cross' data points with the track map suggests that there are at least three situations that seem to stand out:
- rolling onto the gas early in the apex to track-out transition
- trail braking
- left foot braking
The second two are limited to specific corners.
- The right hander into Oak Tree and the climbing left at the end of the back straight are good trail braking candidates.
- A few no-shift turns where the left foot brake helps keep the car balanced.
Still want to look at this some more, but my eyes start to cross after 30 minutes or so of this stuff.
cstreit 02-05-2004 03:50 PM
Tony,
Why don't you look at the G-circle only for those sections of the track?
