problems with microphone on new video setup
I had sort of posted this question in another thread but figured I would start a new thread.
I have a new video setup with a lipstick cam, Canon camcorder, and I'm using a small microphone very similar to the ones that people here have bought from supercircuits. Instead of using the 12 volt 8 AA battery pack that are sometimes used with these, I wired mine into my fuse panel to supply 12v power to it. Only problem, I'm getting alot of buzzing on the microphone. Which is annoying on the video. I went to Radio Shack and bought a filter and ran the power wire for the mic through the filter. Made a slight difference I would say, but nothing significant. Any ideas? I still have my 12 volt 8 AA battery power pack that I can wire it to, but would prefer to use the 12v supply from the car's power if possible. Then I just have to flip a toggle switch to turn on the lipstick camera and mic, and I'm good-2-go. Any thoughts? What can I try? Brian
Brian Keith Smith |
Does the buzzing stay constant or does the sound change as the engine is revved? Mine changed as the engine reved and I bought a filter for my MSD system from them and the buzzing stopped.
Interesting...
Brian
Brian Keith Smith |
Thanks John.
I have a TEC3 system with dual coil packs. I wonder if that could be it if your MSD box was your problem. Yes, it oscillates with the revving of the engine. Brian
Brian Keith Smith |
I'd contact the TEC3 tech people and see what they have to eliminate electrical interference.
There is a very good chance that the buzzing isn't electrical interference, but rather that you're "overloading" the microphone. The small one from supercircuits is a "high-gain" microphone that is meant for recording quite sounds, not for recording engine sounds...
I was never able to get my supercircuits mic to work in my car environment. I tried electical filters (like you did), I tried foam around the mic, I tried putting the mic in the middle of a towel and stuffing it under my seat - I tried everything - but never got decent sound. I ended up having to get a microphone amplifier and mics from RaceCam, which works PERFECTLY. However, it was more like $150 as opposed to the $12 for the supercircuits mic, so it was a hard pill to swallow. But, now that I have it, it was worth every penny. I have two channels and I run one mic to the tail pipe and the other I stuff in my helmet so I get my sometimes-off color live account of the race I'm going to wire the second channel into my race radios for next season.Dean
'86 Carrera cab (euro) Spec Miata |
Now that is some good info!
Thanks Dean! I don't want to spend $150 either but I'll certainly check it out. Brian
Brian Keith Smith |
One minor but very important correction - I had to get a microphone PRE-amplifier, not a microphone amplifier.
Dean
