Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Plavan's Avatar
What should I expect- I'm "Testing" a Ducktail at Willow Springs
I'm going to play with the "Darkside".....
I'm testing a Ducktail this weekend at a VARA race. What should I expect? I have never raced a car with any type of Aero (Kinda sad considering I have been racing W2W since 1998...lol). I know the Ducktail is not much, but better than my stock decklid.
I'm just hoping it will lower the "Pucker Factor" through turn 8 and 9.
Will I notice a difference at all?
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 03-26-2012, 04:29 PM
Todd Simpson's Avatar
IMO, yes. I've run a duck for many years, and recently did a few sessions without it. 90mph cornering I did not notice a big difference, but braking from 130, right at initial application, was much more stable with the duck back on.
This was back to back sessions, everything else the same-about as consistent as an amateur like me can be.
I like the look without, too bad!
Old 03-26-2012, 06:08 PM
Plavan's Avatar
I also like the look without the Duck, but the Cheater Z's in my class have been getting faster with their Spoilers. If the difference is not that great, I plan on throwing the stock lid back on. I was just at WS two weeks ago, so I can compare my lap times.
I sort of want it to be better, and I sort of want it to be the same. I like the no Aero look.
I guess I will find out soon.
Ps- those decals look great.
Old 03-26-2012, 06:17 PM
I raced with a Duck for several years. I then put on an IROC tail and improved my lap time by about 1.5 seconds at Sears Point. I'd say a Duck is probably worth about the same over no aero. The tail just takes some of the pucker factor out of the high speed sweepers.
-Andy
Old 03-26-2012, 07:23 PM
IROC is what you want. Got me 4 seconds at Fontucky over my duck. Add a splitter to balance it out...
Old 03-26-2012, 08:19 PM
Plavan's Avatar
I'm sure it is faster, but I'm keeping it with a vintage look.
Chad Plavan
Old 03-26-2012, 08:25 PM
I was running about 125 through 8 with my duck config, over that and it's a real thrill ride but it has to be better than nada tail...
Old 03-26-2012, 09:39 PM
My experience is the same Zulu. For me with the duck and the front RS spoiler 8 is usually flat out and 125+.
Tinker
Old 03-26-2012, 10:30 PM
The data is out there, I believe in the RS book. I can't remember it exactly, but it was approx...
No tail and front spoiler and there is 400 pounds of tail lift above 130. Duck tail negated this down to about 150 pounds of lift. The IROC tail actually produced positive downforce. My real life experience supports this for sure. But, the IROC tail would not be "correct" for the early 911. After my experience with the two tails, it was pretty obvious why they only offered the duck tail for 72 and 73.
Old 03-27-2012, 05:17 AM
Super Moderator
cstreit's Avatar
Isn't that a SWB car?
You already have huge huevos driving one fast to begin with... Why shrink them with aero?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-27-2012, 09:10 AM
Plavan's Avatar
Haha! No its a 69' so its a LWB, but still a handful. WS has always been my trouble track. My best time there is a 1:33. I need to go faster, while leaving my skirt at home. The Datsun Z's keep getting faster and faster with "Their" period correct spoilers. I thought I would play too.
I have a 2 Hour enduro on Saturday, so I figured the Duck would help me at some point during those 2 hours
Chad Plavan
Old 03-27-2012, 10:00 AM
Administrator
Jack Olsen's Avatar
It's not going to make a world of difference, but it will make a difference.
Everybody always talks about turn 8 with aero, but it's the one corner at Willow where -- if anything -- you're going to be slightly slower with aero (although in reality, you'll probably be just about the same). The reason for this is that with our cars (assuming your motor isn't sneaking out huge power), you're flat through 8 no matter what. (If you're not, then you've got your car set up maybe looser than it ought to be?) But if you're flat without the duck, then the only thing the spoiler is getting you is drag.
But aero will deliver dividends at Willow in turns 1, 2 and 9. Those are corners where most of us are not flat on the gas, and the 80+-mph-generated lift is actually making a difference in how the tires hold. Spoil that lift, and you can carry more speed through those corners.
To me, 2 is the corner you want to do all your setup for at Willow. When I run my back-yard hooligan wing, that's the corner where I do my adjusting.
All that said, your VARA cars are light as a feather, twitchy as a teenager -- and you guys build 2.5 liters to pretty healthy numbers. So flat through 8 might not be a given. If that's the case, well...
...then I'm freakin' jealous.
Old 03-27-2012, 10:39 AM
Plavan's Avatar
Thanks Jack. I'm no where near being flat out in 8. You can only turn left so much, in a right hand high speed sweeper. Haha
Old 03-27-2012, 11:11 AM
Racer
winders's Avatar
You car exhibited a ton of oversteer in turn 4 at Laguna. Are you sure you don't have the rear end too stiff or the front too soft? Do you see understeer anywhere?
Scott
Old 03-27-2012, 12:00 PM
Max Sluiter
Flieger's Avatar
Put Pat Long in it with no aero for a baseline, slap the duck on there and ask for his impressions after a few laps.
Old 03-27-2012, 12:34 PM
Plavan's Avatar
Quote de Plavan
Scott
It did. I found a bent front A-arm, and some funny alignment settings. All is good now (I hope). I'm full soft on the rear, and 1 setting from full stiff on the front sway bar.
The funny thing is P. Long was going to be there, but a vacation before his next race got in the way.
Old 03-27-2012, 12:39 PM
Max Sluiter
Flieger's Avatar
You gotta stay off those curbs!
Old 03-27-2012, 12:46 PM
Administrator
Jack Olsen's Avatar
I don't have good data, unfortunately. I have a 1:32 lap with just the ducktail from 2006. I'm flat on the gas through 8 with no tail drama in a 248-hp car that is (I assume) heavier than the VARA cars.
I want to say the VARA cars I've seen are set up 'too twitchy,' but I also have to say that they seem to be driven really well and they go like stink. And full disclosure: I keep getting better lap times as I dial out the push on my car with shocks and sways.
Are you allowed to put a sheet of plastic or aluminum on the underside of the cars in VARA?
Old 03-27-2012, 01:49 PM
Plavan's Avatar
Ohhh great no excuses now. Now I have something to shoot for. That looks much faster in 8 than what I do.
Loose is fast...to a point. Yes, we are lighter. My 2.5L puts out 210hp to the wheels. It makes me wonder since we are lighter, that the lift created is still the same except exaggerated on the light car. Hence the "Too Twitchy" effect.
As far as a sheet of plastic under the car, The Datsun Z guys would notice that in a second. lol
Chad Plavan
Old 03-27-2012, 02:23 PM
moneymanager's Avatar
Chad, I think you'll notice it and on the theory that stability breeds confidence, I think you'll go faster. Most of us have found they need to balance even the ducktail at the front though, with a splitter or something for a bit less lift. See you Saturday. Jim
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 03-28-2012, 12:10 PM
