Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Aslet's Avatar
Where to take brake temp?
What spot of the brakes should I take an IR temp reading at? Would any spot on the rotor work or right at the base of the brake pad (where it touches the rotor)?
Old 08-05-2011, 02:51 PM
racer's Avatar
What exactly do you want to measure? Pad temp? Rotor temp? caliper temp? Some of your ability to measure is clearly impacted by the size/type of wheel on the car too.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-05-2011, 06:50 PM
Max Sluiter
Flieger's Avatar
You only get surface temperature with the gun, so your brakes might still be on the verge of fade (high core temeperature) even if they look alright to the gun.
Old 08-05-2011, 07:04 PM
Aslet's Avatar
I just want a general temp. I'm only starting to record info and temps, so I want to start simple. What would be the best temp to know? I don't have brake fade issues, I did get some hairline cracks on the rotor surface during an event. So maybe rotor temp would be best?
Mainly I want to see if I need better brake cooling (or ifi just need to brake less).
Old 08-05-2011, 07:05 PM
