WHEEL SIZE STAGGER F/R older RSRs?
Hello Peeps question.. On theses older RSRs, the wheels , and certainly tire sizes are huge in back compared to front. ( also hugely wider stance of course) did the cars actually use 2 diff size wheel diameters? say 15/16, or 16/17 f/r ? or is it just an illusion based upon the tired size> i love this look , as most of us do. can it be achieved on a LH NA carrera backdate just with flares and spacers ( and turbo arms)?
thanks frank
Max Sluiter
935s used 19" rear wheels if I remember correctly.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Smart quod bastardus
Correct.
Porsches reasoning was that the rules limited tire width (which they were already at the limit) and to increase tire footprint Porsche increased wheel diameter while staying at the width limit. So yes they ran different diameters as well.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
yes on the 935s which ran taller(19") rear tires to reduce the point loading and tire temps in the rear tire carcasses, similarly the latest 991RSR's are using 20s for the same reason
thanks bill are you sayong that in the picture above ..the front and rear wheel diameters are the same? thats hard to believe.. is the tire size just so much bigger in rear (in tallness/aspect ..not width) that it looks like a bigger wheel, and hence thereally aggressive stance of the car? still confused thanks frank
Whose to say, in the photo above, that those are factory "correct" sizes? Judging by the context and other cars in the pics, theres nothing to say that those wheels are not original, and nor are the tire sizes.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Max Sluiter
That photo looks to have a good deal of fish-eye to it. Wide angle lenses shooting a car that isn't that close will do that. Exaggerated perspective makes the wheels look taller in the rear. It also makes the 911 look smooshed/shortend.
If you haven't already seen it, I would suggest watching Moby and the Warhorse Gang. It is an incredible historical documentary of Porsche racing dominance in the 70's and especially the 80's. There is one segment that discusses just that one thing about wheel sizes and how Porsche used diameter to get around the width rules if the sanctioning bodies at that time. It's really long but totally worth the 4hrs or so of length.
Mike '89 CARRERA #402 |
