Certified Porsche addict
914 B-pillars structual?
I'm looking at the SCCA Solo Prepared rules to see if I can get through testing and tuning without a roll bar or cage...
17.12 SAFETY A. Roll Bars/Roll Cages (Aluminum is not an allowed material.) 1. All open Prepared Category vehicles shall have at a minimum a roll bar complying with Appendix C. 2. It is recommended that all cars be equipped with a roll cage meeting the requirements of the Club Racing GCR. Compliance with this requirement supersedes the need to comply with Section 17.12.A.1. 3. Roll bars and cages may either be bolted or welded to the vehicle. The way I read it, I'll at least have to put the targa top on unless that sail is considered a roll bar.
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 |
914 Geek
The targa bar was considered a roll bar waaaaaay back when, but I do not believe that it has been in a decade or more. Put the top on for your test & tune. Anecdotally, the top contributes noticeably to the chassis stiffness of the car, and did even when these cars were new!
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
914 Geek
You should be able to put it on, but I am not sure how well it will stay on. The front seal (the expensive one, naturally!!) seems particularly necessary to keep the roof from rattling and being loose. Possibly loose enough to come off? I'm not sure.
The front latches are adjustable, but the rears are not--unless you put some tubing over the pins, at least. To re-state: The rear should be fine; it presses against the top of the Targa bar. The front gets pulled forward so the tongue of the roof fits in the groove in the windshield frame, and the seal across the frame may contribute to the security of the latch. --DD
