Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Racer
winders's Avatar
Fender Damage from Tire Kick Up
My air-cooled race car does not have inner fenders in the wheel wells and the fiberglass is getting damaged by kick up. The front is where it is really noticeable.
What solutions have you found to this problem? I was thinking about epoxying some type of medium density rubber (neoprene maybe) in the areas where the damage is occurring.
Thoughts? Suggestions?
Thanks!
P.S. Toby, this is your chance to be useful!!
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 02-12-2015, 05:29 PM
chapo's Avatar
Foam. Black, buy a roll from McMaster Carr or Granger. Spray glue. No long term damage, saves your paint.
Patrick
Old 02-12-2015, 06:14 PM
Mahler9th's Avatar
http://forums.pelicanparts.com/porsche-autocross-track-racing/610662-material-undersides-fenders-quarters.html
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-12-2015, 07:00 PM
Evan Fullerton's Avatar
I have thermoformed thin polypropylene sheets in the underside of fenders and glassed the corners in to keep them put. Right about 300 degrees and the sheet of plastic roughly cut to size will lay into an upside down fender like a sheet of paper. Adds a couple pounds but the stars go away and it won't hold moisture.
Old 02-12-2015, 10:03 PM
Yep, I've done that!
joeblow's Avatar
Ummm how about rubberized spray undercoating? Always worked for me. One coat is 2mm thick and does the trick and is very light.
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 02-13-2015, 05:34 PM
disband
juanbenae's Avatar
HA! well played sir!
I was thinking some of these might do the trick, they come with their own adhesive...
Old 02-14-2015, 12:02 PM
mdm944S
Michael Muren's Avatar
I bought 1/2 inch thick high impact rubber foam from McMaster Carr. Cut to fit fender shape over tire. Glued into place with 3M weatherstrip adhesive. Then covered with a thin layer of Fiberglas. Never had another issue with stones.
Old 02-15-2015, 10:25 AM
disband
juanbenae's Avatar
so, I set that one on the tee for #3 , where you at,, yo?
yes, scott, I will bring some from my stock as I just went to Costco....
this thing on? tap-tap
Old 02-15-2015, 06:45 PM
Racer
winders's Avatar
Toby,
I am not a split tail nor do I drive like a guy that is one.......so I have no direct experience with that type of product.
P.S. I am still waiting for a response in the CV joint cage thread.
Scott Winders
PCA GT3 #3
Old 02-15-2015, 09:04 PM
