Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
mhariush's Avatar
Coolant tank hose leaked and broke
I have a 2006 V6 and I have a couple of coolant leaks. There doesn't seem to be much info out there, and the S and Turbo are different than the V6 right?
I have a coolant leak on the driver side of the engine, looks to be a plastic parts high up on the engine. Right above the oil cooler. Anyone know which part this is? Auxiliary Water Pump?
And today I noticed a strong coolant smell and I looked on the passenger side and saw it dripping from a hose coming from/to the coolant tank and connecting to two other hoses. I touched it and it instantly broke off, barely touched it. So now I will have to replace.
Any thoughts on this hose, just replace this and fill up coolant in the reservoir? The same happened on my old 996 and I just topped off coolant and never had any issues. Getting those brittle pieces of plastic out of the hose was not fun though.
I think it's this part Part #: 955-106-058-02-M100, does that sound right?
The pictures aren't very clean, but its the hose that has the print on it.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-14-2018, 05:49 PM
mhariush's Avatar
Where is the auxiliary pump located on the V6? The water pump is at the front behind pulley I assume.
Old 08-14-2018, 05:53 PM
