Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
jrblackbox's Avatar
04 Cayenne starter replacement
I am in the process of replacing the starter on MY 04 CayenneS. I have extracted the starter without removing the coolant pipes which are metal. It took me awhile to get the starter out, but it did come out. The problem I have is getting it back in. I can't seem to wiggle it back in, so my question is, can I just loosen the rear bracket(opposite thermostat) that is holding the coolant pipes just a little so I can squeeze the starter under? Upon looking at it, I think I should be able to do it, just need a little more room.
Old 03-23-2019, 08:10 AM
jrblackbox's Avatar
Ok, I removed the bracket (3 torx head screws) closest to the firewall, this resulted in a just enough of play in the pipes where I was able to finagle the starter in. A lot easier than removing the pipes! Thanks Pelican!~
Old 03-23-2019, 11:16 AM
I did my starter this past week, I ended up pulling out my aluminum coolant pipes that I previously installed. Since I did that it was easy putting the starter back, I also put in a new thermostat and water pump. Starts like knew again and runs cool.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-28-2019, 12:21 AM
