-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Air Conditioning (http://forums.pelicanparts.com/showthread.php?t=1037416)
N1bl@aol.com 08-14-2019 09:26 AM
Air Conditioning
2006 Cayenne Turbo
Right side(passengers side) AC doesn’t get cold. Driver side is ok.
Dmitry at Pelican Parts 08-14-2019 01:07 PM
Hello and welcome to the forum! It could be a defective 'blend door' motor or actuator. Other members will likely chime in as well.
RNajarian 08-26-2019 06:20 PM
Dmitry is probably right, but to be sure you should pull the codes.
I’m having a problem with my A/C blower so I put my Durametric scanner on the car and got 3 related codes.
I’m going to pick up a relay from our host then replace the front blower relay, clear the codes and see if that fixes the problem. After a while I’ll check the codes again to see if the other 2 come back.
I’ll try and upload a photo of my Durametric scan
