Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Air Conditioning
2006 Cayenne Turbo
Right side(passengers side) AC doesn’t get cold. Driver side is ok.
Old 08-14-2019, 09:26 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! It could be a defective 'blend door' motor or actuator. Other members will likely chime in as well.
Old 08-14-2019, 01:07 PM
My other ride is a C-130J
RNajarian's Avatar
Dmitry is probably right, but to be sure you should pull the codes.
I’m having a problem with my A/C blower so I put my Durametric scanner on the car and got 3 related codes.
I’m going to pick up a relay from our host then replace the front blower relay, clear the codes and see if that fixes the problem. After a while I’ll check the codes again to see if the other 2 come back.
I’ll try and upload a photo of my Durametric scan
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 08-26-2019, 06:20 PM
