Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Cayenne S timing chain replacement
Would anyone recommend anything else to be done to a Cayenne S engine while dealer has it out for a timing chain replacement?
Old 09-10-2019, 02:58 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Since you're essentially removing the front of the engine, any maintenance items that may need to be replaced can be done then - water pump, thermostat, tensioners, etc..
Let us know if you have any other questions.
Old 09-10-2019, 11:10 AM
I understand what could be done but was wondering what is recommended. If the engine has 186000kms on it then it might be wise to change some items that are known to cause problems. Would you recommend anything be changed in the interests of good maintenance? I understand that if it ain’t broke mentality but some other owners may have experience they would like to add.
Old 09-10-2019, 05:36 PM
Administrator
From what a colleague mentioned, any wear and tear items are recommended to be replaced if they're accessible during the timing chain replacement.
Old 09-11-2019, 01:16 PM
Hmmm - maybe I am not being clear. Are there any other components that would be worth changing on an engine that has done 180K kms? I know that there will be wear and tear on almost everything but other owners might suggest replacing the alternator or the water pump etc etc I dont want to replace everything but only what is recommended at that kilometreage
Old 09-11-2019, 04:05 PM
Crankshaft seal.
Old 11-18-2019, 10:09 AM
