Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
2004 Porsche Cayenne 4.5 NA cranks but doesn’t start
Hi, I got a 2004 Porsche Cayenne with the 4.5L V8 non turbo and it won’t start. The engine cranked over for a while and nothing, after a few seconds of cranking on the third or fourth try it had a little life in it but still didn’t start. It has a new starter and a new battery so I know neither of those are the issues. I pulled on of the spark plugs and checked if it had spark and it did, I’ll check the rest later today but I believe they all have spark. I checked to see if there was fuel pressure, I don’t have a pressure tester so I just emptied out the fuel rail so their was no pressure then turned it to the run position for a minute then pushed on the valve at the front and it had built up pressure again so I’m assuming it isn’t the pump. Any ideas on what it could be?
Old 11-01-2019, 03:06 PM
Information Junky
island911's Avatar
It's a complex system of valves and sensors that all need to be 'happy' for fuel to be delivered.
I was surprised, quite a while ago, that this little valve could cause start problems. http://forums.pelicanparts.com/porsche-cayenne-macan-forum/506799-incorrect-purge-flow-durametric-fault-code.html
Point is that you could likely benefit from getting a fault code reader.
Old 11-03-2019, 06:36 AM
Administrator
Dmitry at Pelican Parts's Avatar
Above member is absolutely correct - a code reader will be really helpful in pinpointing where the issue is coming from. We'd recommend a Durametric tool or a Schwaben tool if you'd like a simplified version. Links below to both - let us know if you have any another questions.
Durametric Diagnostic Tool
Schwaben Scan Tool
Old 11-04-2019, 02:49 PM
Send a message via AIM to fintstone
Check the fuel pump fuses. If both are good, take one out and try to start it. If no good, put that one back and remove the other and try again.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-03-2019, 05:41 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Coil Ground and Harness.
Check Very Important...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 12-03-2019, 03:22 PM
