Cayenne engine - first impressions
Got to take a good look at one, overall I have to say I am impressed.
On first glance, you immediately think "928" Overall size and shape are similar. some specifics Didn't get a chance to ask a whole lot of questions, and couldn't look for as near as long as I would have liked too but from what I saw. 8 cyl, 32 valve motor Interference motor (like that was a surprise) It has a TIMING CHAIN - Bravo for Porsche!!! Serpentine belt for accesories (alt, PS, etc) Oil pump is driven off of a seperate chain from what appeared to be the crank. Again, a nice feature - if and when the oil pump needs service, you don't have to tear apart the motor to get at it. Integral oil heat exchanger; oil filter is a removable filter element (a la 996) coolant is routed through the exchanger to bleed off oil heat. Waterpump appears robust - feeds two seperate "feeder lines" controlled by a single thermostat. Radiator appears very robust - looks like they dumped the aluminum and plastic and went to all metal - supplemental cooling by two electric fans Single fuel rail feeding all 8 injectors Throttle body enters intake manifold through the front center, 8 ducts feed the cylinders There are two air pumps - was not able to determine if they are for intake or exhaust All wheel drive system appears very robust. On par with a Carrera 4 Massive power steering cooler - covers roughly 25% of the radiator. Brakes 3 piston front calipers, 2 piston rear calipers Air leveling suspension a la 959 Drawings and diagrams available upon request In short Gentleman, I saw them put a 996 on a trailer with this thing and run it through a slolom yeah, it is an SUV, but loooking it over, I have to say they kept it true to the name and the crest.... AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information Last edited by AFJuvat; 03-15-2003 at 09:55 PM.. |
Banned
Isn't the Cayenne's engines running in the new Porsche FabCar
Prototypes? Or a upcoming Lemans racer???? |
I'll believe that engine has arrived when I see it powering a deuce coupe...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Warren Hall Student
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
