-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   955 engine swap (http://forums.pelicanparts.com/showthread.php?t=1073719)
Motobellini1098 09-21-2020 06:03 PM
955 engine swap
Hi can the knowledgeable amongst us please tell me if the engine from a 2004 turbo v8 4.5 can be swapped out for a 2006 normally aspirated v8 4.5 , If the compression is reduced to suit. Can the turbos exhausts ect be swapped over? Many thanks, Paul
guru944 10-18-2020 06:59 PM
I believe NA engine block has Cast pistons and TT engine block has Forged Pistons. They both have the same forged Connecting Rods. also turbo oil feed lines are on TT only block...
NA block has 11.5 :1 compression.
It could work...Later
