Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
955 engine swap
Hi can the knowledgeable amongst us please tell me if the engine from a 2004 turbo v8 4.5 can be swapped out for a 2006 normally aspirated v8 4.5 , If the compression is reduced to suit. Can the turbos exhausts ect be swapped over? Many thanks, Paul
Old 09-21-2020, 06:03 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
I believe NA engine block has Cast pistons and TT engine block has Forged Pistons. They both have the same forged Connecting Rods. also turbo oil feed lines are on TT only block...
NA block has 11.5 :1 compression.
It could work...Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 10-18-2020, 06:59 PM
