Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
My other ride is a C-130J
RNajarian's Avatar
Side View Mirror Convenience Light LED Upgrade
While finishing up a problem with my folding driver side view mirror I noticed my convenience light was out.
http://forums.pelicanparts.com/porsche-cayenne-macan-forum/1116184-folding-mirror-inop.html
Accessing this bulb is surprisingly easy and the upgrade takes less than 5 minutes.
1) Make sure the mirrors are extended.
2) Remove the mirror (Wayne has a write up how to do this)
3) Using bird beak pliers wiggle the socket out of the lamp
4) Using an automotive grade blade LED bulb place the new LED bulb in the socket MAKE SURE YOU HAVE THE RIGHT POLARITY or the bulb won’t work. The OEM bulb is a Sylvania 2825
5) Lock and unlock your door to verify it works.
6) Assembly is the reverse of disassembly
You do NOT need to remove the top cover of the side view mirror. I chose to use contact cleaner on the electrical wiring.
I should note that the LED bulb I installed gives light in 360 degrees. They do sell LED blade bulbs that concentrate light downward. I may pick up a couple of those bulbs and see the difference.
New LED bulb illuminated
Original Incandescent bulb
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 06-01-2022, 09:43 AM
RNajarian's Avatar
Here are some photos I borrowed off Amazon of the LED lights optimized for this application.
DISCLAIMER: I have NO financial interest in these types of products
Old 06-02-2022, 06:24 AM
