Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
No Expert
jgparker's Avatar
Cayenne Oil Change
Hi all,
It's been a while. Call me dense, but how do you change the oil on a Cayenne? I just bought a 2004 S to tow my 911 to the track and I can't find a drain plug. Do you have to suck it out of the dipstick? I did a search and didn't find a how to.
Also, has anyone installed a trailer hitch on one? I hear you can't do it without having a dealer change the programming.
Thanks,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-26-2009, 04:55 PM
Send a message via AIM to JHoffman Send a message via Skype™ to JHoffman
You need to remove the under trays. First you need to remove the brake ducts on each side they are the phillips screws. Then remove the 10 mm bolts for the tray. Remove both the drain plugs (8mm hex) and then remove the filter. Let it all drain to a drip and replace all the seals.
Old 05-27-2009, 04:25 PM
