Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
What to look out for with Used Cayenne
Will soon be looking for a Used Cayenne.
I do not put more than 7500 miles/year on a vehicle.
Budget Low $20's.
What are known issues one should look out for/avoid?
Old 02-18-2013, 04:29 PM
914-6Porsche's Avatar
I'm surprised that someone hasn't chimed in by now. This board is fairly quiet this time of year and really isn't very busy anyway on the Cayenne's. What are you looking for, a V6, S or T? We have an S and a Turbo. I don't know anything about the V6 other than I had one for a loaner once and it was really gutless but really mundane. The Cardan drive shaft is an issue and has probably been changed by now in your price range along with the coolant pipes on the V8's. Some have had problems with the spark plug coil packs and I believe that they extended the warranty on those to 100K. I have a 2004T and some of these were taken care of by the dealer because of the 60K warranty. Some of them have not and aren't cheap to fix. A coolant T connection should have been changed with the coolant pipes but mine wasn't. My 2004 was the 2nd year and has had some other weird things go wrong but I'm sure it isn't typical with the later models. I have horrible AM and really marginal FM reception.
My plate has been really full but I finally spent about 4 hours to check it out. I have not found an antenna cable/connector for the radio, so it is receiving off of a very small stub of a SMA/SMC type connector. Try to do most of the servicing yourself, like brakes($900 at the dealer or about an 1-1 1/2 hr and $300 to do it yourself, oil changes(dealer $200), light bulbs. There is a lot of information on all of the above on all of the forums, search around. The wife has a 2006S and it has been great so far. My T has about 85K miles.
Old 02-19-2013, 05:00 PM
Fixer's Avatar
Look to buy from a Porsche enthusiast who was religious about oil changes and took care of the car. Be very careful it hasn't had bodywork as that usually leads to problems with corrosion.
Matt
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 02-21-2013, 12:10 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
go to rennlist Cayenne section and READ. tons of material on buying a p!g.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-26-2013, 08:44 PM
CaveVan
Send a message via AIM to Streetcrawler
Just my opinion here
Tons to negative biased BS on the Rennlist Cayenne forum. A bunch of guys that never got over the fact that Porsche made an SUV. Renntech and 6SpeedOnline seem to have a much more balanced and factual viewpoint
Old 03-01-2013, 10:53 AM
SCOTITUDE's Avatar
Read the tech stuff, not the whining if you want to educate urself on the p!gs faults.
Old 03-01-2013, 11:09 AM
CaveVan
Just pointing out that even the tech stuff there gets muddled in BS. Making the Cayenne sound MUCH worse than it really is.
Old 03-01-2013, 11:10 AM
SCOTITUDE's Avatar
you own a cayenne? have you worked on cayennes? have any experience with them that you can state the BS is worse than it really is?
I have done both extensively and can state from experience that there is planty of good info there.
2008 E93 M3 DD
Old 03-03-2013, 07:30 PM
CaveVan
Thumbs down
Yep. I've had an 04 CTT for many years and done all the wrenching on it myself.
All the common things and and I'm the one who figured out to use CTTs control arms on an S or CTT first, among other things.
Nobody said the "tech" there was bad. But the negative attitude and bashing of the Cayenne has been bad on that site. Not so much recently but the last 3-4 years it was so bad that they chased many people away.
Old 03-03-2013, 07:38 PM
Send a message via AIM to fintstone
I have an '04 CTT. Love it...but like all Porsches, not cheap to repair if you have someone else do it. Just had the coolant pipes replaced after a massive leak.
I drove both the TT and the normally aspirated version. They are very different as the TT not only has huge HP (450), but it also has much better brakes. It tows very well. Radio reception is poor as stated above. nav system is also neanderthal. Mine has heated seats and steering wheel. The wheel also telescopes so it is easy to get comfortable. Lots of back seat room for large adults. Bixenon headlights were an option and well worth the price here in the country as they have saved me from hitting deeer several times. It drives like a 911...except faster than most. Engine/exhaust has a sinster rumble like a hot rod...but interior is quiet. Great vehicle and a bargain for the money.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-28-2013, 05:51 PM
