Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Is very busy
TheRedSlantnose's Avatar
Porsche Crest 2nd gear
For a while, I've noticed our Cayenne GTS starts out in 2nd gear and not 1st. Why does the GTS start out in 2nd gear instead of 1st gear? Is 1st gear too low of a gear or something?
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 06-19-2014, 06:39 PM
Ari
My 2004 Turbo does the same thing, and it only has 6 gears (I think your 2009 has 8). I looked into that a bit and it is temperature-dependent. The car will start out in 2nd gear unless it has a reason to shift into 1st. It seems to avoid 1st on flat ground unless the ambient temperature is in the 30s or lower.
Old 06-20-2014, 06:17 AM
Is very busy
No, mine's a 6-speed automatic as well.
Jason
Old 06-20-2014, 01:06 PM
It depends on the machine. Maybe you have a sports version??
Old 06-21-2014, 06:21 AM
jrumiano's Avatar
Starting in 2nd gear should be normal unless it's cold or you manually shift to 1st, or if you switch the PSM (Porsche Stability Management) off.
BTW my Cayenne S becomes a beast when the PSM is switched off!!
John
Old 06-21-2014, 06:35 AM
If you turn on Sport Mode it will default to first gear automatically. I think they do the second gear start for fuel economy.
2011 Cayenne S
2001 Boxster S
Old 06-24-2014, 01:06 PM
