Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
914-6Porsche's Avatar
Cayenne Coolant Pipe Replacement
Has any one on this forum change their coolant pipes? I can't find a tech article or thread about the subject. Any info would be appreciated or point me to the thread.
Old 06-19-2014, 02:12 PM
jrumiano's Avatar
Coolant pipe replacment
This should help.
http://bd8ba3c866c8cbc330ab-7b26c6f3e01bf511d4da3315c66902d6.r6.cf1.rackcdn.co m/Porsche_Cayenne_V8_45L_Coolant_Pipe_Refresh_Kit.pd f
Old 06-19-2014, 04:51 PM
Thanks jrumiano. Those are great instructions!
Old 06-20-2014, 11:28 AM
If yours is a turbo, get the two coolant T's and change em while you are in there. Here is some info: Coolant T Crapola - Rennlist Discussion Forums
Old 06-21-2014, 04:39 PM
Thanks mtnrat. I'll do that. This is preventative stuff I'm doing.
Old 06-23-2014, 04:23 PM
Its really not that bad a job " worst part is when you get the old tubes out most likely the old
Rings from the tube are going to stay in there, it's a real task to slowly chisel them out
Be prepared to literally sit on the engine while you bend over to see them.
And when I say you have a hair folical of space to get the new pipes in I'm not kidding.
It's a good one solid day job when you have all the parts and do some cleaning.
Old 06-24-2014, 11:14 AM
Maltese Falcon's Avatar
If the engine happens to be out...much easier.
Have your tech remove the crossover coolant manifold and pull the aluminum coolant tube out.
Then clean and prep the mating surfaces for a quick TIG welding session.
This will be the last place the coolant system will fail !
Marty
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 06-24-2014, 10:51 PM
