-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Cayenne Coolant Pipe Replacement (http://forums.pelicanparts.com/showthread.php?t=816999)
914-6Porsche 06-19-2014 02:12 PM
Has any one on this forum change their coolant pipes? I can't find a tech article or thread about the subject. Any info would be appreciated or point me to the thread.
jrumiano 06-19-2014 04:51 PM
Coolant pipe replacment
This should help.
http://bd8ba3c866c8cbc330ab-7b26c6f3e01bf511d4da3315c66902d6.r6.cf1.rackcdn.co m/Porsche_Cayenne_V8_45L_Coolant_Pipe_Refresh_Kit.pd f
914-6Porsche 06-20-2014 11:28 AM
Thanks jrumiano. Those are great instructions!
mtnrat 06-21-2014 04:39 PM
If yours is a turbo, get the two coolant T's and change em while you are in there. Here is some info: Coolant T Crapola - Rennlist Discussion Forums
914-6Porsche 06-23-2014 04:23 PM
Thanks mtnrat. I'll do that. This is preventative stuff I'm doing.
AVDCAV 06-24-2014 11:14 AM
Its really not that bad a job " worst part is when you get the old tubes out most likely the old
Rings from the tube are going to stay in there, it's a real task to slowly chisel them out
Be prepared to literally sit on the engine while you bend over to see them.
And when I say you have a hair folical of space to get the new pipes in I'm not kidding.
It's a good one solid day job when you have all the parts and do some cleaning.
Maltese Falcon 06-24-2014 10:51 PM
If the engine happens to be out...much easier.
Have your tech remove the crossover coolant manifold and pull the aluminum coolant tube out.
Then clean and prep the mating surfaces for a quick TIG welding session.
This will be the last place the coolant system will fail !
Marty
http://forums.pelicanparts.com/uploa...1403675346.jpg
