Cayenne Coolant Pipe Replacement
Has any one on this forum change their coolant pipes? I can't find a tech article or thread about the subject. Any info would be appreciated or point me to the thread.
Coolant pipe replacment
This should help.
http://bd8ba3c866c8cbc330ab-7b26c6f3e01bf511d4da3315c66902d6.r6.cf1.rackcdn.co m/Porsche_Cayenne_V8_45L_Coolant_Pipe_Refresh_Kit.pd f
1985 3.2 911 |
Thanks jrumiano. Those are great instructions!
If yours is a turbo, get the two coolant T's and change em while you are in there. Here is some info: Coolant T Crapola - Rennlist Discussion Forums
Thanks mtnrat. I'll do that. This is preventative stuff I'm doing.
Its really not that bad a job " worst part is when you get the old tubes out most likely the old
Rings from the tube are going to stay in there, it's a real task to slowly chisel them out Be prepared to literally sit on the engine while you bend over to see them. And when I say you have a hair folical of space to get the new pipes in I'm not kidding. It's a good one solid day job when you have all the parts and do some cleaning. |
If the engine happens to be out...much easier.
Have your tech remove the crossover coolant manifold and pull the aluminum coolant tube out. Then clean and prep the mating surfaces for a quick TIG welding session. This will be the last place the coolant system will fail ! Marty
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
