Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Buy them, sell them
Adam's Avatar
Cayenne Turbo boost levels
I've been reading European reviews on the new Cayenne and I've come across similar power and performance claims, but Motor magazine seems to have mis-quoted the amount of maximum boost the Cayenne runs.
It reads "... the Cayenne turbo runs a whopping 1.6 bar at maximum boost..." and by my maths, isn't that somewhere in the region of 23psi?
Even hardcore Pelican HP-Junkies like Mike, Juan, Merv and Rarlyl8 are too frightened to turn up the wick that far.
Perhaps these journalists aren't hacks afterall and the Cayenne is massively force-fed, but can anyone say for sure?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 12-17-2002, 06:12 PM
Senior Member
Running a chip in my VW TDI I see 30psi boost before it settles back down to 18-19psi. I know of a few people that have changed turbos and run different maps that sustain 30-35psi boost in their TDI's.
Maybe the pepperwagon does get 1.6 bar but I doubt that is sustained.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 12-17-2002, 06:26 PM
The actual figure is 0.6 bar or 8.7psi. See Car and Driver Jan 2003 issue for a preview test of the car.
Journos always screw this up. When the 996 turbo first came out, some were saying it boosted to 1.8bar instead of 0.8bar.
Old 12-17-2002, 06:51 PM
pwd72s's Avatar
Will this get me to the club for tee off time???
Old 12-17-2002, 06:53 PM
Mike the mechanic's Avatar
The 1.6 bar rating has to be atmospheric, so minus the 1 bar atmospheric pressure, leaves you with 0.6 bar. 1.6 bar in a big V8 would make over 1000hp!!! Although my Tdi makes 1.6 bar at about 140hp!!!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 12-17-2002, 08:37 PM
Buy them, sell them
Adam's Avatar
Thanks, Guys.
I was really starting to marvel at the advances Porsche would have had to make with this motor. I mean, they'd need 4:1 compression, water/ethanol injection, refridgerated intercoolers etc etc to make it streetable on 23psi!
I guess some over-zealous motoring journalists just get a little too excited.
Old 12-17-2002, 09:03 PM
WydRyd's Avatar
Damn! The Journalist isn't the ONLY one that got excited then. What an anti-climax
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-17-2002, 10:16 PM
beepbeep's Avatar
Not necessarily, i've run 1.2 bar on my 2L 9.1:1 CR SAAB, and i know people who run more. Cossie-guys frequently boost over 1.8 bar...
It's just that our aircooled heads are poor when it comes to turbocharging...they are big, promote detonation and must run pretty cool. On the top of that, there is no knock-detection circuit, so everything needs to have substantial margin.
New engines have watercooled heads (= more EGT), 4-valves (= more flow), electronic knock detection and can typically stand up to more boost.
Also, more boost doesn't necessarily means more power...you can run more boost with delayed ignition timing but it won't make more power, just heat ;-)
It's totally different picture when it comes to diesel engines beacuse they work with surplus of air, doesn't knock in traditional sense and are built sturdier...
Thank you for your time,
Old 12-18-2002, 12:40 AM
