-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   955 4.5 engine replacement with turbo model block (http://forums.pelicanparts.com/showthread.php?t=940880)
OzUsa 12-30-2016 04:23 PM
Does anyone know if the 955 turbo engine will fit in the non-turbo car.
I am planning to replace the engine soon if the turbo fits, I could strip the turbo parts off and setup as non turbo. Then not worry about cold start issues with the cylinder walls.
Thanks,
kennethg 01-01-2017 08:52 AM
Will it bolt in? Yes. Will everything else work? Pretty much, but the biggest thing is a drop in compression from 11.5-1 (S) to 9.5-1 (Turbo). Search Jake Raby in the forum for more info on the cylinder scoring issues or on Rennlist.
OzUsa 01-01-2017 09:49 AM
Thanks Kenneth,
Determined 01-30-2017 09:02 PM
I was considering doing the same for a twin turbo, does the transmission also need to be from the turbo (donor)? And does it need the turbo ecu and harness?
