Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
My other ride is a C-130J
RNajarian's Avatar
Blower Motor Question
Hi Guys,
I'm hoping someone can help me shed some light on an acting up blower motor.
Car is a 2005 V-6 with 49,000 miles. Recently the family travelled to Palm Desert (outside temps got up to 120 degrees F.) Entire time A/C worked as expected except for one time when the A/C seemed to shut off. I fiddled with something and the system roared back to life. Before heading home I verified A/C r134 level (yes I travelled with a Can of r134 and a gauge) was normally filled, right in the middle of the green zone.
Today I was using the A/C in 90 degree F heat, and all seem to work well when at one point the blower motor seemed to shut off. I could feel cold air slowly coming out of the vents and in fact I had a thermometer in the vent and verified 50° coming out of the vent (albeit very slowly).
I turned the fans to maximum in both the front and the back vents to no avail. No change in the flow of air. I shut off the AC turned it back on and again no improvement. I shut the car off and started again with no improvement. Since there was some very cold there slowly drifting out of the vents I continued home and continue to play with the A/C settings, temperature, fans, recirculation, AUTO etc.
Then on it's own after about 10 minutes the fan seem to slowly come back to life and then began to blow high-volumes of air as expected.
I'm curious if anybody else has had this type of problem and if so how did you repair it? I am thinking it may be the blower motor regulator, which Wayne has a Tech Article already ready for me to use, but before I take the car apart I was wondering your thoughts.
http://www.pelicanparts.com/techarticles/Porsche-Cayenne/35-ELEC-HVAC_Blower_Fan_and_Regulator_Replacement/35-ELEC-HVAC_Blower_Fan_and_Regulator_Replacement.htm
Thanks for your thoughts.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-03-2017, 03:38 PM
Information Junky
island911's Avatar
I am thinking it may be the blower motor regulator --me too. (BTDT)
Old 07-04-2017, 08:35 PM
goat's Avatar
Had a similar problem.
I replaced both the motor and the regulator at the same time. But the regulator is usually the culprit.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 07-13-2017, 10:23 AM
RNajarian's Avatar
Thanks Guys.
I drove the car for a week, no problem then it reappeared. Blew at 1/4 power. Then after 10 minutes 100%
Going to swap the regulator soon
Regards
Old 07-13-2017, 11:53 AM
