Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest Swooshing, water rushing sound by drivers doorby.
So annoying, this sound when I accelerate or brake. Was not other in frezzing cold months but its back in June. Saw YouTube videos on draining door sills but not clear how to drain water with aero side skirts on my 2006 S Ti.
How does one resolve this and prevent this from persisting? Any suggestions please reply. Thank you in advance...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 06-14-2017, 03:20 AM
Mike80911's Avatar
I had the same problem on my 04 Not sure if the aero kit changes things but there is a drain plug at the bottom of the door pull the plug and all of the water will drain out. If the kit is blocking the drain plug you might have to remove the door skirt to get to the plug
89 930 Cab Black
11 Cayenne
Old 06-16-2017, 08:48 AM
+1 on maybe removing the skirt
On my '05 Turbo the drain was plugged with the anti-corrosion wax. Gentle prying popped it out and heat melted the wax away on the plug. Probing the cavity did not bring out any debris.
But there was a lot of water!
'99 Guard's Red C4 ; 2005 Cayenne Turbo, 09 Aston Martin V8 Vantage
gone:
W8 SW
couple of Z-3 M's, couple of Lotus, Couple of MG's, Couple of Triumph's
Old 06-16-2017, 05:23 PM
