Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
04 Turbo Air Spring Replacement
Anyone know how I can remove the air fitting from the air line? I'm installing a new air spring from Arnott and it says to remove the brass fitting from the air line so the line can be pressed into the new fitting in the new spring.
Follow the video at about 2:20....
https://youtu.be/I5VX3lSssGY
Sent from my Nexus 6 using Tapatalk
Old 06-30-2017, 05:27 PM
Information Junky
island911's Avatar
looks like you need to pull the compression fitting out first. - The small diameter brass bit.
Old 07-04-2017, 08:46 PM
