Clicking as suspension works- control arms?
Howdy,
When going slow I notice a slight clicks nose coming from the front left suspension. I'm thinking control arm bushings as the possible culprit. Before I dive into it, has anyone replaced the control arms themselves and have any tips? |
Just found this article here. Will be doing this. Porsche Cayenne Ball Joint Bearing and Bushing Tests (955 GTS/S/Turbo 2010-2014) | Pelican Parts DIY Maintenance Article
Clicking I would assume as a half shaft, check your boots for cuts and leaks
I recently replaced the lower control arms. The biggest difficulty I encountered was separating the ball joint. Make sure you understand how the eccentric bolts are configured; only rotate the nut when removing.
| All times are GMT -8. The time now is 05:01 PM. |
