Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Question Clicking as suspension works- control arms?
Howdy,
When going slow I notice a slight clicks nose coming from the front left suspension. I'm thinking control arm bushings as the possible culprit. Before I dive into it, has anyone replaced the control arms themselves and have any tips?
2008 Porsche Cayenne S
2004 Porsche 911 Carrera
Old 07-17-2017, 10:21 AM
Just found this article here. Will be doing this. Porsche Cayenne Ball Joint Bearing and Bushing Tests (955 GTS/S/Turbo 2010-2014) | Pelican Parts DIY Maintenance Article
Old 07-17-2017, 10:23 AM
It'll be legen-waitforit
stealthn's Avatar
Clicking I would assume as a half shaft, check your boots for cuts and leaks
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 07-19-2017, 06:13 PM
ninelevenick's Avatar
I recently replaced the lower control arms. The biggest difficulty I encountered was separating the ball joint. Make sure you understand how the eccentric bolts are configured; only rotate the nut when removing.
Old 07-21-2017, 12:48 PM
