Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
wkrtsm's Avatar
What's my 600 HP in a 912?
Since my 912 is no longer a 912, because it now has
  • SWB-to-LWB (911 '69-71 steel trailing arms)
  • 934 transaxle
  • Elephant coilovers with Bilstein 911 S struts, GT3 front suspension, Boxter brake upgrade, monoball trailing arm bushings
  • Tarrett's 935 spring plates and monoball camber plates
  • 6-8 month "welding party" for shock towers, spring plate mounts, trailing arm mounts, camber plate housing, secondary engine mounts, fuel cell mount tabs, radiator V-plate, mods for GT3 subframe installation
  • 930 turbo fender flares
  • 1973 RSR 2.8 composite front & rear bumpers
  • Speedhut gauge upgrade
  • WEVO 930 shifter
  • MOMO steering wheel
about the only thing that's 912 are the new wheel bearings, new steering box, rebuilt upper steering shaft joints.
The powerplant is a new 430 HP 6.2L LS3, for which I pulled and drove the heads to TSP (Texas Speed) and got CNC of ports & chambers, double valve springs, titanium retainers. I also personally installed a TSP stage 2 cam and Comp trunnion kit (needle bearings for rocker arms). TSP said they dyno'd new engines with what I did and results are 580-590 HP. (fyi - cam upgrades place significantly more stress-travel on valve components, so everything needs to be upgraded.)
The build link is here
Pic below shows the final engine prep:
Installing the stage 2 cam with Lucas green assembly lube:
Rocker arms with Comp trunnion kits installed:
Old 02-23-2025, 10:57 AM
Thanks, Subscribed.
What do you think your rpm going to be in top gear at 60mp/hr?
Old 02-26-2025, 06:26 PM
wkrtsm's Avatar
Originally Posted by dtakenname View Post
Thanks, Subscribed.
It's about just what I thought, near 2000 rpm. 3rd and 4th gear in 930 transaxles are essentially overdrive. I could easily do 80-90 mph in first gear getting on the freeway.
Old 02-26-2025, 10:22 PM
Yan2947's Avatar
Just read through your build link above. Great work. Can't wait to see more progress. Are you going to use one radiator up front?
1989 911 LS1
Old 02-27-2025, 04:54 AM
Banned
jkkarrow's Avatar
Great work. Look forward to more pictures upon completion ..
Old 03-01-2025, 12:00 AM
sweet build, pics of the car itself?
Old 03-13-2025, 11:30 AM
Cairo94507's Avatar
Excellent; will watch for updates. Love the LS motor.
'71 914-6 #0372
'17 Macan GTS
Old 03-13-2025, 01:39 PM
