Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Yan2947's Avatar
Thanks! And tell us a little about your Mercedes...
1989 911 LS1
Old 06-25-2014, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #361 (permalink)
R.I.P.
drmatera's Avatar
well, traffic was crazy and the weather sucked last night but I did manage to drive thru my neighborhood in 2nd gear going from 3200-3500rpm. People thought I was nuts. I found out 2 interesting things:
1) temp goes from 196* to 198* within the first 15-20 seconds but stabilizes there. Now I didn't do it for 5 miles/5 minutes as I just didn't have the real estate to pull that off.
2) Why on earth would you even consider running 4000rpm down the road for any period of time? Change the gear ratio
Old 06-26-2014, 06:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #362 (permalink)
Yan2947's Avatar
Well, 4000 rpm is 80 in 5th gear. I agree, all these conversions should swap out at least 5th gear.
1989 911 LS1
Old 06-26-2014, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #363 (permalink)
lin7310948's Avatar
my conversion with the radiator in front runs 180-190 on hot days on the interstate. but with the 930 transaxle i am only turning 2200 rpms at 70 mph. and my car has a small frontal opening as it is a ruf yellowbird front spoiler and i dont want to cut the opening larger! the engine is a mast motorsports ls7...427 cubic inches..and makes 700 chp!
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 06-26-2014, 07:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #364 (permalink)
Yan2947's Avatar
Larry, can you drive down a nice road in a low gear at 4 rpm for about 5 miles and let me know your temp. If we all have hi temps then it is all about gears.
Yan
1989 911 LS1
Old 06-26-2014, 08:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #365 (permalink)
Yan2947's Avatar
Does anyone have instructions/photos/video for a g50/01 5th gear swap. I am looking for a real tall gear for highway quiet and low rpm.
1989 911 LS1
Old 06-27-2014, 08:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #366 (permalink)
R.I.P.
drmatera's Avatar
my tuner also said it sounds like a fuel or timing issue. High rpm and low load needs a decent amount of timing
Old 06-27-2014, 09:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #367 (permalink)
Yan2947's Avatar
Already nicely tuned to correct the issue. I think (and may be wrong) that all of the ls setups will get hot around 4000 rpm (especially after 5 to 10 miles) unless they have a large radiator. Tall gears probably solves all the issues and should be a priority in all swaps. These motors like to run with low rpms I think...
1989 911 LS1
Old 06-27-2014, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #368 (permalink)
Straight shooter
Lapkritis's Avatar
Seconded. Setup depending, I keep 34-40° advance in cruising bins. An EGT probe can help dial in a nice, safe burn.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-27-2014, 10:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #369 (permalink)
R.I.P.
drmatera's Avatar
yessir
my Benz cruises down the highway at close to 80mph well under 3000rpm
Old 06-27-2014, 12:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #370 (permalink)
lin7310948's Avatar
yan it is rainy in our area. maybe i can make a run later in the week. as a note, i did not use the renegade hybrids radiator. i had the radiator built by griffin which is very close to me. i had it built as large as i could fit into the frontal opening. it is sealed to the sides and to the inner fenders as well as the hood. seems the faster i go the better it cools. probably due to the relatively small opening in the ruf front spoiler!
Old 06-29-2014, 07:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #371 (permalink)
Yan2947's Avatar
Larry, what size radiator and fan setup did u use? I am not worried about speed with anyone. Gear size totally makes a difference. I am hoping just even going slow at 4000 rpm for say 5 to 10 miles will show the true temps of the car. I know the car gauges are never perfect but hoping you have a computer of some sort hooked up. I use my iphone with Rev2 and a wifi adapter with the obd2 but anything that reads the temp is fine. If someone with a good radiator setup gets hot with high rpms then it really is all in the gears... Thanks!
Yan
1989 911 LS1
Old 06-29-2014, 04:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #372 (permalink)
Mitch Leland's Avatar
I'll chime in on this, I have 3 radiators on my 966 C4S, now C42. I had a taller ring and pinion installed, in 6th gear I'm showing 80 MPH 2,375 RPM . My temp at highway speed never gets over 190 degrees even in 100 degree temps. However my oil gets hot, at the same temps it will go to 260 degrees. Am in the process of looking into an oil cooler.
I noticed that pulling a grade in 95-100 temps that the oil temp rises quickly. I just returned from 4,000 mile trip in the car so I had lot's of time to look at all of this.
Bottom line, unless you're going to drag race your car, I would go for the taller gears, changing the ring and pinion changed all of the gearing, expensive, but well worth it... At 70-80 MPH my car is quieter than with the 3.6 engine, mostly because the RPM's are lower.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-29-2014, 09:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #373 (permalink)
Yan2947's Avatar
Mitch, thanks for chiming in. You have two of your radiators in your front fenders (stock)? Do you have photos of that portion of your setup? I am wondering if I added an additional radiator in a front fender in my 89 911. Would I need to cut anything to vent or are they just naturally vented in the fender and what size are they? Fans? Or would a center front radiator require or work with a stock valance with a cutout of the valance (this being just an extra radiator).
I do plan on getting the taller 5th gear but I know I must be very close to a fully working setup already and with slightly extra cooling I may be able to maintain temp at any rpms. Not that I plan to ride hard at high rpms but if I conquer the temp issue now I won't have any issues with added hp later. I have thought of adding an extra cooler in the rear right fender or one of the front ones. Just not sure which way to try.
Is there any chance you could ride your car at the higher rpms for about 10 miles (4000 rpm) and let me know what you reach? Do it a slow speed or any speed. I have trouble understanding why no other person has chimed in after doing this. I don't think 4000 will hurt anything even though it may be a bit loud... It will give me a starting point with what size radiator really works!
1989 911 LS1
Old 07-03-2014, 05:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #374 (permalink)
Cooling...
Yan,
Where I installed the 3rd radiator in my 966 won't be the same for your 911... I used the same mounting brackets as the factory "Tiptronic" oil cooler mount. I then connected the 3rd radiator in series with the two factory radiators.
Right now I have the car on my lift working out the new oil cooler so it's not going anywhere any time soon. I had 3 weeks of fun driving so I'll give it a rest while I do some more upgrades.
The only thing I can say is you can't have too much cooling capacity, why not change out the ring and pinion instead of the 5th gear. Then you have taller gearing through out the RPM range. If nothing else I would consider taller wheels...
I would also consider an oil cooler, my LS3 motor only holds 5 qts of oil and being in the rear of the car I don't think it's getting the same airflow as a front engine install. I know the same LS motor in the current 2014 Corvette is a dry sump engine. The point here is if you want a factory operating, everyday car I think you need to look at all of these options. If you just want a 0-60 hot rod then you don't need some of this.
Mitch Leland
Old 07-03-2014, 08:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #375 (permalink)
Yan2947's Avatar
Mitch, what is the H x L x D of that center radiator? I wonder if I could run one in series with my rear one. No fan on it? No venting in back? Do you have the part number for it and the brackets? Would it fit on my 89?
The rack and pinion is a bit expensive right now. I have been restoring a 52 MB...
1952 220 Sedan W187 build restoration
So funds will have to wait and the one gear is not too bad.
1989 911 LS1
Old 07-03-2014, 03:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #376 (permalink)
Yan,
I can't find the dimensions right now of my 3rd radiator. I've got shop drawings and details but I just can't lay my hands on them right now. But I can tell you my radiator that I had custom built will "not" fit your car. It's not vented as my radiator system is a closed system. And I don't have a fan on the new 3rd radiator. So far it doesn't seem to need one. However once I get my oil temp uncontrol I'll revisit that.
Mitch Leland
Old 07-03-2014, 05:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #377 (permalink)
Yan2947's Avatar
Mitch, Just looking at my setup with my stock valence/spoiler - you are right - won't fit. I purchased this front spoiler from Better Bodies a while ago. I know that the cooler would fit with it but I really like the stock look. Thoughts? It would allow for the extra cooler. I also attached a CBR cooler from ebay that says:
CBR PERFORMANCE COOLING PRODUCTS SMALL OFF-ROAD OIL COOLER -10JIC W/ 9" SPAL FAN
8"X9.5"x2.25 Fans- Single 9" SPAL
If I could mount it somewhere it would be great as a second radiator mounted in series also. The rear right fender may work or near the rear bumper. or just the taller 5th gear...
1989 911 LS1
Old 07-03-2014, 06:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #378 (permalink)
ChrisP911's Avatar
Have you had any luck with your cooling.
Old 07-20-2014, 06:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #379 (permalink)
Yan2947's Avatar
Everything cools well except at the 4000 rpm range. I am going to add a front center 996/997 radiator and see if that is an immediate fix. Steve at renegades is always a help even with my toy jet setup. I am going to run some inch and a quarter lines up front and mount it temporarily, running it in series. If that solves the cooling then I will add the radiator into my spoiler or my 935 spoiler. This will tell me if I have or don't have enough square inches on my radiator... After that is solved I can add a tall gear also.
Not a single person did the 4000 rpm challenge! 😞
1989 911 LS1
Old 07-20-2014, 04:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #380 (permalink)
