nice. and if the conversion is done properly there is little reason not to be pleased. both of my conversions have the fuel system wired into the Mast Motorsports ECU.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp |
Hey Hal ---> how's the project coming?
Jeremy ![]() 1971 911 Wide One 2.7 2012 911 Cabriolet 2011 Cayenne S |
Yes.........how's the project coming?
AAEEEEE!
Steve Laissez les bons temps rouler |
Swapper and Ruiner
Howdy all!
A little update. I lost my shop space earlier this year so I transitioned it out to another shop. I'm having it finished commercially. Yeah, I know. Yikes! But the shop is well known and he's done a lot of high dollar stuff including being the original fabricator/designer for the exhaust system on the Hennessey Venom. It's getting close - I think. More pics as they come available from him. Oh, and it's for sale if anyone wants it. Thanks, Hal
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html |
Love those Fuch wheels you have pictured
Swapper and Ruiner
OK. No luck selling it. I decided to finish it.
The front trunk is painted and the fuel tank is cut for an in tank pump. ![]() I think the front panel came out great. How about those little chevy bowtie cutouts! Next up, we'll get the battery and a/c installed. Then the duct that goes from the bumper to the body. H
Champagne on Beer Budget
Looking Great Hal! When you get some free time you should come visit the new shop
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
looks good. mine is almost done. had it on the dyno and after making 342 hp we had to pull it off the ********* welder left chunks of metal behind in the tanks and messed up the fuel pump. So now I have to get a new fuel tank and pump. Well the pump arrived the other day. once I get the tank it goes back on the dyno to make 400 to 450 hp
Swapper and Ruiner
Chris, I'd love to see how much your car weighs. Have you had someone put in on race scales? I wish I'd done the Mitsu motor now. It has to be lighter than the LS1 - not that the LS is heavy. It was 50 lbs lighter than the 6. It's probably 100 lbs lighter than a turbo 6. H
Swapper and Ruiner
Work has resumed!!! Thankfully. It sat for a year almost while some non paying jacka$$es car sat on the lift - stranded there because of a lack of parts.
But that car is off and this one is on. Completion is imminent. Here's the update photos for this week. The AC/Heater Unit is installed and plumbed. Yes, the battery is located below it in the smugglers box, but the unit comes out with 2 bolts and has enough service loop in its connections so that nothing needs to be disconnected. We'll also install extensions from the positive side of the battery so we can jump and charge remotely. There'll also be an on/off switch. ![]() Here's another view. ![]() We also welded in some gussets for the shock towers and cut the notch for the intake into the crossmember. ![]() That's all for now but more updates will be coming quick.
What is that AC evaporator unit?
It doesn't support a heater also? (by any chance I missed it?) Thanks |
Swapper and Ruiner
It does support heat. The two copper colored fittings on the near side are for hot water. Hal
1) What an idea! How good is the AC -- any possibility you can compare it to an original Porsche AC setup? 2) I heard of someone on this forum who was planning to route engine oil to provide heat. Any chance that was you?? 3) Anyone's thoughts of whether a copper system set up for water would support hot oil flow also? I'm thinking that "normal" other cars have heaters that get over 200 degrees, plus a safety factor, but maybe oil gets too hot? Any thoughts? The only reason I was sticking with my factory headers was to be able to plumb in heat -- but I'd love to replace them with tuners, a la RarelyL8's. |
Sorry -- did not realize that I had ventured into the CONVERSION side -- so obviously youse guys can run water to your evaporator heater coils.
HOWEVER, if there are any suggestions for my question about using engine oil through heater coils in the evaporator, PLEASE GIVE ME YOUR OPINIONS. Thanks. |
Swapper and Ruiner
Hal, whats the part number for your A/C
800... toward the bottom:
Custom Aftermarket A/C Systems & Replacement Parts for Hot Rod, Classic, & Vintage Cars/Trucks - 700/800 Series A/C Systems
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
Thank You
Hal can you show us more pics of you AC unit inside the car and how it works Thanks Chris |
