G50 5sp main shaft length
Hi, are all g50 5sp main shafts the same length? . i know people shorten them but i need to go the other way and need one slightly longer at the clutch spline area.
it's a g50/00 btw.
gearhead
The turbo ones are approximately 30mm longer.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
ah cool thanks. Iv'e worked out i need a extra 15mm of spline on the shaft.
Why would you shorten it?
gearhead
People shorten them for a variety reasons, the most common being to get clearance to put the later gearbox into a chassis that predates the G50s. For a 930 or 915 to G50 swap.
Would any one know what grade of steel the main shaft is made from ? need to get the correct welding rods before starting to modify my shaft.
