Trying to buy my 1st Porsche
Wont bore you with my entire long story and my love for cars, Porsches and just about anything with motors. I've been looking for a while (year plus) for a 911sc to be my first Porsche.
I'm curious to hear from all of you here with much more experience than me, your thoughts around this being my first Porsche, ability to maintain it, work on it etc.
I've located on I may pull the trigger on. Early 80's with 80k miles on it. Not sure of the best price for it. Its in great shape, but I'll figure that out later.
Let me hear your thoughts. Thanks in advance.
Old 03-07-2019, 01:14 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - is there a link or photos of the car that you can provide? Our members will be able to assess the car better with more details - history, any mods, your mechanical skill level, etc...
Old 03-07-2019, 01:25 PM
1980 911SC at Top Gear Porsche in NJ
My mechanical skills would be "moderately advanced" if I had to describe it. I've worked on bikes, boats, several Toyotas, etc to a good extent. Never a German car in my life.
http://showroom.auction123.com/topgear_imports_llc/inventory/11263/1980/Porsche/911/91A0141332.html?leadsource=Showroom|topgear_import s_llc
Old 03-07-2019, 01:30 PM
An air cooled 911 is one of the easiest cars I've ever worked on. Plus, nearly every possible project is well documented here on Pelican. These cars were well overbuilt, they don't build 'em like it anymore.
Matt - 84 Carrera
Old 03-07-2019, 01:34 PM
Administrator
Have you swung by and seen the car in person? Based on some Google and other reviews, the place seems very questionable.
Old 03-07-2019, 01:49 PM
SalParadise's Avatar
True - but many original parts actually wear out quite quickly. Sometimes it's better to upgrade a high-wear oem part with a better one.
Old 03-07-2019, 02:10 PM
That drivers seat look like it has a lot more than 80K miles.
Speedos are easy to switch out on these cars and it is sitting a bit crooked? If your serious about the car I would puul it to see what the date code is on it regardless of what they tell you.
Old 03-07-2019, 03:43 PM
sugarwood's Avatar
You're a car guy.
You sound like you want to DIY.
This is a great forum resource
Go for it.
Let's hear your story!
1986 Bosch Icon Wipers coupe.
Old 03-07-2019, 03:45 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
I agree that they are relatively easy machines to work on, but they also have serious design and build flaws that need to be addressed sooner or later (am talking about things like the garbage dilivar head studs used for decades and electrical worst practices), are extremely old, and are remarkably expensive to repair when something significant goes wrong.
Old 03-07-2019, 05:00 PM
Former Options Trader !!!
The reputation of that dealer is questionable at best.
Someone can correct me if I am wrong but I believe that car would have come with an 85 mph speedo, so its a swap.
Car looks pretty tidy but nothing beats seeing it yourself. Pictures hide tons of stuff. Odd that so many bolts are rusted but not the associated parts.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 03-07-2019, 05:37 PM
My car had 81k when I got it and the seat looked like that. Leather is good but had an overweight owner. The foam is shot and may have a broken frame. Mine did. New foam and frame repair is easy. Local shop removed the leather, I welded the frame, they reassembled with new foam and original leather. $250.00 fix
The speedo switch was in 80. Maybe a late 79 car?? The fact the original AC compressor is still there makes me think it could be an all original car.
Plan on putting $20k into it. The suspension, brakes, fuel lines, gaskets, etc. are all done. The car is 39 year old.
Derrick
Old 03-07-2019, 08:49 PM
Don’t get attached to one car. There are lots of them out there. I found both my p-cars after deals fell through and thought I’d never find the one I wanted.
Old 03-08-2019, 02:25 AM
Bought my 1st P car ('88 Carrera sunroof coupe) month ago. Was open to model/ year w budget limit. I'm not a mechanic by trade but mechanically inclined. Was looking for good runner w minor problems I can fix myself. Ended up finding the car thru networking.
Good luck!
Old 03-08-2019, 04:34 AM
Looks like a decent car. Someone put on the front spoiler or took off a tail. The price is not bad if the miles are right and it the history is good. Not much to go on in the description. PPI is needed. My advice is to look at and drive several as you can then weed out the dogs. When you look at a good one you will know it. There are many on the market now and travel to look at it if its not local. I looked at and drove many 930s across the US before I decided on the one I have.
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 03-08-2019, 06:04 AM
War584
Agree - cars seems decent with some issues that would suggest it may have more miles than shown. Being from CA, I get a little nervous when I see rusty bolts (AC & undercarriage) - make sure there is no rust in the usual spots around the windows, front fenders, etc. Also, roof looks wavy in front. Test drive it to make sure it doesn't leak or howl (too much).
Old 03-08-2019, 11:14 AM
I recommend joining PCA and looking at their classifieds - then get a PPI - that's how I bought my 911SC. If you can (on an SC) try to get:
- head studs that have been replaced
- improved chain tensioners (oil fed)
- pop off valve in airbox
- turbo lower valve covers
I am by no means a mechanic - but even I managed a valve adjustment.
Good luck
1983 911SC
2005 911S
Old 03-08-2019, 03:29 PM
Believe original speedo would be a 85 mph.....like many this one was likely swapped out.....was a typical item done in the 1980's on these cars....
Old 03-08-2019, 03:47 PM
Do what your doing ,ask lots of questions. Try to go for lots of comparison rides/drives.
1979 SC
1986 Carrera 3.6 L+
Old 03-10-2019, 10:46 AM
If you can wait a bit I believe that getting a car from a private party might be your best route... Especially from an owner who's had the car 3 years plus. You'll hear more of the history and get first-hand information. I've found that many of the best cars trade owner to owner and never see a dealer.
Old 03-10-2019, 11:22 AM
