disband
juanbenae's Avatar
and here I thought the "exterior thickness" blast would be what hooked ya!!!
Old 04-14-2019, 01:00 PM
CBA CBA is online now
Originally Posted by CBA View Post
Juan,
What is your motor and carb setup? I’m sure I hunt through the forum but since you here.....
Figured it out went to your garage. Nice setup.
Old 04-14-2019, 01:02 PM
disband
juanbenae's Avatar
Juan,
early, single plug, big port 3.oL, recurved dizzy, 9.5/1 JE pistons with the webcam 120/104 grind, topped with weber 40's. ive jetted it to my sweet spot with 160 mains, 60 idles, F8 ET & 175 air corrections at sea level.
if I had it to build over I might have used a different cam profile that should have influenced a leaner idle circuit. the 120/104 is great from about 3k RPM & up through 6700 RPM (rev limiter set at 7000rpm) with a ton of pull. I had the heads done with stiffer spring and titanium retainers anticipating wanting to get into the higher rev ranges.
in all my research and limited experience carbs are just gunna need to run rich. there is a fine line between lean coughing up through the stacks, flat spots in transition and achieving a good usable power throughout both circuits. I obsessed on it early on, but reading plugs regularly throughout the tuning process and since with them looking good ive grown used to it.
Last edited by juanbenae; 04-14-2019 at 01:27 PM.. Reason: mis remembered cam grind profile number now accurate
Old 04-14-2019, 01:20 PM
disband
juanbenae's Avatar
thank you for the kind words!
Old 04-14-2019, 01:23 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Speaking of which, I hear that Nathan is sporting posterior thickness , butt don't know if that is true, or just fake news!
Old 04-14-2019, 02:49 PM
disband
juanbenae's Avatar
^^^ raw, love the bold font use, way to drive it home my man!! but, if you use the boldened font too much it loses it's effectiveness... it's akin to writing fragile on every box when you move. what you'll find is no box is then shown any extra care...
I suggest if you MUST multi-bolden points in the same post to capitalizing your main-est point.....
Old 04-14-2019, 04:02 PM
Good point (not THAT point! ) about limited use of bolden text, Tobs, but I am not very familiar with the concept of moderation. Hell, look at where I live; the land of gluttonous excess in all things (food, homes, truck size, hat size, sports stadium size - including middle and high school stadiums, guns, and even fake boobs!). That said, I'll attempt to temper my TexASS sized ways and follow your more rational bolden level of posting.
If I recall, when pNutz got his nads nipped by "his sensei", that dude only use one bolden word to batter pNutz's cheeks (all four of them!) - hmmmmmmm!!!
Old 04-14-2019, 04:43 PM
disband
juanbenae's Avatar
that was some serious vengeance like whoop a$$ poor silly pnutz endured that time... I felt bad for him even with my under developed caveman ability to feel compassion.
id prefer my sensei be mad at me over him being disappointed in me any day. you know ol nutz lost some sleep over tony-boy being so condescending & hurtful to him when he only wants to please...
Old 04-14-2019, 05:26 PM
I'd wager that ol' pNutz had a case of baboon-butt after that lil' incident that not even the most potent, hemorrhoidal balm could soothe!!!
Old 04-14-2019, 06:04 PM
Originally Posted by Matt Monson View Post
The boost boys will never know the anazing sound of the engine as a set of carbs crack open. The closed system and the impeller on the turbo really hinder the sound that is a flat six on full song.
Agreed about that, but one way that a CIS Turbo sort of makes up for that is when you replace the huge, mailbox air filter housing with a short, cone filter mounted directly on the air metering assembly's intake (the turbo CIS has a suck through air metering arm/housing - not a blow through like the n/a CIS, and does not operate in a vacuum state), and then remove the vacuum limiter (aka- deceleration valve) so that closed throttle response is the same as a n/a car (revs no longer hang and slowly reduce during closed throttle) - this results in a very nice sounding whooosh noise, through the yuuuggggeee air opening for the metering arm/disc, that says, "ballz!!!" (totally different than the sound of BOV venting to atmosphere - hard to describe in text). My father likes to joke that the noise mimics the downward movement of the fuel gauge needle.
Old 04-14-2019, 06:17 PM
Still here
pmax's Avatar
Nice gratitude for someone who saved your azz from another whipping by the CIS dude.
Old 04-14-2019, 07:12 PM
Ha ha - Toby's sense of humor did not square with some of the Pelican Puritans in the thread I think you are talking about!
Old 04-14-2019, 07:31 PM
Still here
pmax's Avatar
Yeah, the caveman turning tail after one punch was a letdown !
Old 04-14-2019, 07:35 PM
One thing I've learned first hand is that it is a fool's errand to argue with the forum self-righteous; most often best to just move on to a more tolerant and accommodating barnyard
Old 04-14-2019, 08:01 PM
Still here
pmax's Avatar
... even dick pics, LOL !
But yeah, tech forum can use some humor, it's oh so serious over there... fireworks too when the wrong parties engage.
Old 04-14-2019, 08:32 PM
disband
juanbenae's Avatar
im much more complicated than you or your pony-boy will ever know apparently nutzie. once the Nancie's had complained enough to have that sweet image removed I was done enhancing that thread by continuing to contribute...
sometimes I think you get it, and then you say sum stupid ***** and im not so sure...
Old 04-14-2019, 08:36 PM
War Vet
matt930s's Avatar
With friends like pnutz.....
Dr. Phatt
Old 04-14-2019, 09:42 PM
Still here
pmax's Avatar
What image ?
Wait, there is another caveman azz whupping thread besides the aforementioned CIS beatdown ?
Old 04-14-2019, 11:03 PM
Dayyyyuummmmnnnn, this thread has it all - even Phatt showed up, instigatin' and perpetratin'!
pNutz, the thread Tobs and I referred to was one in 911 tech where a dude was asking about a basic troubleshooting problem with 914 headlights. Toby posted a funny pic/meme making fun of that, and a couple sensitive guys took offence. A moderator then deleted the meme.
Which CIS thread has a beatdown in it? I missed some asshattery and am feeling left out!!!
Old 04-14-2019, 11:35 PM
To be fair a properly modified turbo has amazing sounds of it's own.
The turbo whine combined with the buzz of the flat six that is drastically louder when the twin waste gate open up on boost.
There is no hiding the sound of an engine when that's going on.
And all that is complemented with amazing cackles & pops at shifts and on decel.
To me it's the best sounding car ever. And the daily complements back it up.
Plus if your engine doesn't scorch the paint under your bumper, it should.
Butt what do I know. I'm just a Big Ol Di*k Head
Derrick
Old 04-15-2019, 08:11 AM
