My true colors are red, white and blue. Yours.. primary yellow. ![]() B |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Your memory is skewed. I wish you the best but... truth is I saw you treating someone else like you treated me in the past and it pricked a nerve. You and I have never agreed to much, nor for that matter on anything. Yes, I offered to buy you a beer in the past and IIRC I was scoffed at. I stopped posting on here because it was a large waste of my time. However, I do periodically read the forum and I did post when someone who had bought my 73T was misrepresenting it and some members ( Pmax I believe) even welcomed me back. I never came back here because you and a few of your mates believe you own this forum and it's content.
No worries really my time is limited and best spent on my family and other pursuits like flying perhaps a subie powered duct taped prayer mobile, or teaching law, etc. :-). Take care. B |
Still here
Welcome back. Hope you and MM bury whatever hatchet (?) there was. End of the day, just hobbyists sharing a common passion. Don't take online rants too seriously, ask Raw', he knows that all too well
gearhead
Mighty Meatlocker Turbo
:1) All years utilized the same turbocharger (the horrendous, 3K 3LDZ) and ignition system (same fuel system, too, except for the later Lambda fuel head that does not affect acceleration), so they all have the same, shiity, "Jekyll/Hyde" throttle response in shiity, stock trim. 2) Where do you get the "more power" than later numbers figure? Nothing about the 78-79s would indicate superior power over the later models, and in fact, the thermal reactors, and accompanying atrocious turbocharger plumbing (much improved in later years) would indicate inferior engine performance. 3) The non-Lambda fuel head of the earlier years is not bigger - the metal fuel lines to the injectors are, but the smaller lines on the later years have been dyno proven to not choke fuel supply. That fuel head is made of cast iron (susceptible to rust, both inside and out), whereas the Lambda head is cast aluminum, and the iron head uses a metal diaphragm that is known to become dempled in the event of fuel pressure spikes, where the rubber alloy diaphragm in the Lambda head does not dimple (it can degrade over time, however, and would need to be replaced - much easier to re-seal, in that event, than the metal version). The cast iron head flows a little more fuel in stock form, but the Lambda head can be modified to outflow the iron head, regardless of mods done to the iron version (dyno proven). 4) 78-79 did not have cats, but they did have thermal reactors - which do you think is more of a performance and engine longevity detriment, and which is easier for an owner to change if he/she/it feels like it? 5) Not so, about the "true 930 VIN" - the later 80s vins have the "930" designation in about the middle of the number sequence, and the "0" is replace with an "X" - an "X" is far cooler than a "0". ![]() 6) Where do you get the "more torquier" idea? The build details say otherwise (especially the already mentioned turbocharger plumbing). Last edited by Rawknees'Turbo; 05-20-2019 at 06:29 PM.. |
You keep swimming round and round in the same lil pond and pooping where you sleep. I'll peer in and every now and then if I like..or not. B |
gearhead
http://forums.pelicanparts.com/9119744-post63.html
You dangleberries need to stop trying to derail my tech seminar with your flagrant flirting!
gearhead
True! |
Curious question: why wouldn't this personal discussion be better served in a private message?
Seems tedious to the two of you and certainly (IMO) is tedious to the "lil' pond". |
gearhead
I’ve said my peace. Sure, it would be better served privately, but he wanted to call me out I guess.
Still here
I am entertained!
Ya see truth is I offered an a hole an olive branch somewhere in the past and he scoffed, so no more. Once an a hole always an a hole I guess, no matter.
OK , back on point the 89 G50 with 66k that ends in 17 hrs on BaT. If that car is bid to low 30's that ought to give y'all a fair indication where the air cooled market is. Damn right it has cooled IMO. And Matt, from here on I'll just scoff at your stupid post privately just like I have for the last few years but when you start treating other members like shyte, darn right I'll call you out. No need for it, it ain't your pond, 15000 plus worthless posts or not. You can PM if you like cupcake but you won't like what I have to say. B |
https://bringatrailer.com/listing/1984-porsche-911-carreara-targa-6/ |
Vaive ,There ya go..
shh-the robot is sleeping
Edit - I’m referring to the 66k one on BAT closing tomorrow.
'88 911 Coupe, 69k miles |
B |
