Registered Minimalist
Identify these brakes/adapters 964?
Hi guys selling this pair of 964 front 4 piston calipers with adapter brackets.
First off, what are they? Secondly what's a good price to list the pair for? Thank you in advance ![]()
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Weapons grade dickhead.
$10 and I'll pick them up on Sunday.
1978 911 SC Coupe Build thread: http://forums.pelicanparts.com/porsche-911-technical-forum/1069069-i-always-wanted-one-these-78-sc-build.html
disband
clean the calipers up, rebuild them, restore the porsche script and you will get a ton from all the guys that want the PORSCHE script poking thru the paddles... how much you want? maybe ill buy them and do what ive suggested.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
gearhead
They are off a Caterpillar.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Deal! Seriously. Local friends ftw.
I agree with you, that yellow is "turrible"
disband
with the weekly "i want to upgrade my brakes" threads from guys with non tracked cars that simply want the look of the bigger brakes there has to be a market for them. have you done any classified research on the calipers and the adapters separately?
Same ones on Emory’s RSR
gearhead
That's because they are standard 964 brakes.
You need to measure the piston sizes. These look to be the later style 964 brakes. The earlier ones had raised cast lettering. If piston sizes are 40/36mm then they are stock 964 front calipers. 30/28mm would make them 964 Late MY rears. 34/30mm would be 964 turbo rears which used a wider 28mm vs 24mm rotor. I have 800 mile like new front calipers and full sets of fully restored calipers and turbo red rears and GL trying to get anything reasonable for them inn this condition. I can't sell the like new ones for a fraction of the cost new. If they are rears they might be worth something to owners of early 964 C2's that have the 2 piston rears, otherwise everyone wants big brake turbo calipers with 993 rears for the 964's. FYI these use the same pads as the 917 or 930 turbo calipers.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others Last edited by Cobalt; 08-18-2020 at 06:06 AM.. |
Great answer ^ Thanks Anthony!
