Slippery Slope Victim
NY65912's Avatar
'80 SC Fix Trans before selling?
I have a older buddy that has a very clean '80 SC that is getting ready to sell. He's going to ask top $ as the car has 75K and runs like a dream. No issues except 1.
However, shifting 1-2 and back is balky and he has to time shifting to make a smooth shift.
The argument is over whether he should put the $ into fixing the tranny or not.
I say yes, absolutely fix the trans in order to get top $ and he says let the next owner do it. He wants to put it on BAT but I think they would hesitate to list a car with a known deficiency .
What say you guys.
Mike²
1985 M491
Old 09-02-2021, 04:33 AM
Crotchety Old Bastard
RarlyL8's Avatar
First make certain this is not a bushing or adjustment issue.
If it is a synchro and the tranny is refreshed that should add to the value unless he already is asking top dollar. If it were mine, and I wanted top dollar, I would make absolutely sure everything is in top dollar condition. If not you need to knock a few thousand off for a tranny refresh and find a buyer willing to deal with that.
Old 09-02-2021, 05:36 AM
NY65912's Avatar
Agreed. He thinks it's not worth the trouble but I think it is selling something of more value and desirable. It's not like he can't afford to do the repair.
Mike²
1985 M491
Old 09-02-2021, 06:06 AM
gearhead
Is this a trick question?
Always fix the car first.
Old 09-02-2021, 06:28 AM
NY65912's Avatar
Not a trick question. I'm trying to make a point. My friend is thick headed and impulsive. Trying to give the best advice and figured that showing him the opinions here will make him see the light.
Cheers
Mike²
1985 M491
Old 09-02-2021, 07:35 AM
He's crazy. Whatever it cost to fix he'll get 2-3x less than than if he sells it broken. People are always going to assume the worst and someone looking to pay top dollar for a car in top condition will probably pass at any price.
_______________________________
1982 911 SC 240,000mi and counting
Old 09-02-2021, 07:45 AM
NY65912's Avatar
I happen to be in a similar situation. My trans is not shifting right, I'm going to open it up this fall, but I'm not selling.
Mike²
1985 M491
Old 09-02-2021, 08:28 AM
undervalued member
juanbenae's Avatar
I like this suggestion. unless he was hard on the thing, or had a trusted wrench look over the thing and declare it is syncros it seems 75K is kinda low mileage. bushings & a top notch gear lube could bring it back enough to to put into a sellable condition.
Old 09-02-2021, 08:59 AM
If I was buying I would expect a discount on a car with known issues that I would be addressing.
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 09-02-2021, 09:44 AM
NY65912's Avatar
Thanks for the responses. I will present this to my friend. He is a P car guy but not very mechanical at all. I am sure this will change his mind and do the sensible thing.
Mike²
1985 M491
Old 09-02-2021, 10:29 AM
gearhead
I would do exactly what I did with my 86 Carrera a couple years ago, before I sold it. Mine had 125k mi.
I dropped the engine. I did a valve adjustment, plugs, wires, and oil. Rear main seal and upper triangle were all resealed. New clutch and pressure plate, and shifter bushings. And fluids. It cost me $10k. I sold the car without a proper ad, for exactly what I wanted to get for it. Oh, and that $10k did include,pdr, a detail with color correction, and ceramic seal, and tires.
Old 09-02-2021, 10:30 AM
NY65912's Avatar
Thing is everything is up to snuff with the car. I think he tries to shift like when he drove a truck. I will see him over the weekend and advise that the car deserves a good going over. Thanks
Mike²
1985 M491
Old 09-02-2021, 02:14 PM
gearhead
A lot of people granny shift the 1-2 up shift when they shouldn’t. 4000-4500, minimum.
Old 09-02-2021, 02:41 PM
War Vet
matt930s's Avatar
Where’s that shifting vid?
Dr. Phatt
Old 09-02-2021, 03:14 PM
gearhead
Suga relocated it after we posted it too many times.
Old 09-02-2021, 03:22 PM
And no "pregnant pause"?
Old 09-02-2021, 04:29 PM
War Vet
matt930s's Avatar
https://youtu.be/AmOwHoJlK14
Dr. Phatt
Old 09-02-2021, 04:47 PM
gearhead
Not rev matching double clutch granny shifting like we know you would.
Old 09-02-2021, 04:56 PM
Troll Hunter
Can't get top dollar when something is wrong. Fix it or adjust your expectation of price.
Sent from my SM-G981U using Tapatalk
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 09-03-2021, 02:51 PM
Brew Master
cabmandone's Avatar
By balky do you mean it takes patience to get into 2? As for 2-1, a lot of guys say "don't do it unless at a full stop!".. I say "Meh". Mine used to bark at me going from 2-1 but that's because the rings, bands, slider and dog teeth were pretty much shot. In my old transmission I could go 1 to 2 pretty smoothly regardless of RPM range unless I was really trying to hurry a shift. It was surprising to me how bad the dog teeth were on 2 when the new owner sent pics. The new owner of the transmission was surprised as well because of how it shifted in the videos I posted.
I think I'd check shift coupler bushings as well as the shift rod bushing. Maybe make a SMALL adjustment on the coupler and consider doing a full clutch adjustment. Then see how it shifts.
Nick
Old 09-03-2021, 04:20 PM
