Gotti Wheels Interest
I have a set of Gotti wheels in very nice shape that I just pulled out of storage. I had them on my 79SC.
Polished/painted center caps, polished lug nuts and 2 spacers for the rears. They still wear a set of 2003 dated Yokohamas that can go with them or removed if better.
What would be the interest on them and value range?
If it is worth my while I'll clean them up and measure the off set and some detailed pictures.
Thanks in advance
Sawyer
Old 10-22-2022, 08:21 AM
War Vet
matt930s's Avatar
I had a similar polished deep dish set and I honestly had a hard time giving them away. Mine were true 3 piece and super light. I finally traded them for a set of one off wheels. I think I had them listed at $900 and kept reducing the price from there with no takers.
That was a few years ago and maybe things have changed.
Dr. Phatt
Old 10-22-2022, 07:24 PM
Reno775
I really like the Gotti wheels but it’s not a wildly popular opinion.
Old 10-23-2022, 09:03 AM
It's a 914 ...
stownsen914's Avatar
I'm personally a fan of Gottis and have had them on two different racecars. They seem to be generally thought of as "80s / Miami Vice wheels." Yours seem to be in good condition which is a bonus. It's a little hard to tell from the pic but do they may have the name Etoile or Gotti on the face. Pretty much the same thing, Etoile took over production of Gottis at some point. I might guess $1000 as a starting point. Take a look at eBay sold listings (it's an advance search option) to check actual sale prices, as a benchmark.
Old 10-23-2022, 05:18 PM
I had several sets that I sold at Hershey a few years ago
They sat there all day then in the afternoon I had a bidding war between 3 guys I think I got
$2500 for the 3 sets
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
Old 10-27-2022, 03:11 PM
Thanks guys, for some reason I didn't get a notice of responses. I just listed them in the for sale to see what happens. The previous owner of my 79 seems to have "updated' the car at some point.
Added a tail, Gottis, stereo, Ungo alarm and cheap production paint job in the original color.
My wife who actually found and bought the car loved the wheels and tail. After I bought her a different car she gave me the SC and I removed all of the above.
I'll see how it goes, I can really use the space they take up.
Thanks again for all your input.
Sawyer
Old 10-29-2022, 07:59 AM
I also sold several set
Old 11-01-2022, 03:55 PM
15s? What are the width(s)?
Old 11-02-2022, 05:30 AM
VZ935's Avatar
Send a message via AIM to VZ935
I like the Gottis. Run them on this Daytona/Sebring veteran IMSA GTO car
A bunch of old race cars
Old 11-05-2022, 01:49 PM
Hi ryans65, these are 16" stock SC width.
VZ935, wow those barrels are a bit deeper than mine. They do go well on a 911, my wife was not happy when I put the Fuchs back on and removed the tail.
Sawyer
Old 11-06-2022, 06:04 AM
It's a 914 ...
@sawyer - you might mention the diameter and width in your ad. I don't think it mentions that info. So they are 6 and 7 x 16?
Old 11-06-2022, 07:43 AM
Hi stownsen914, I did mention 16" in stock SC width.
With the tires on is there a way to measure the width?
I didn't state specifically the measured width due to the tires but they do wear the stock 205 & 225 16".
Sawyer
Old 11-06-2022, 08:47 AM
It's a 914 ...
If you lay them flat on the floor and put a board across the top of the tire, you can measure from the floor to the board. Then subtract out the amount the tire bulges past the rim (x2). And subtract another 3/4" for the tire bead lips.
Old 11-06-2022, 09:43 AM
Ok, here is what I come up with using the recommendation of stownsen914.
Hope this helps as it seems the rims are wider than stock with stock size tires mounted. See if this make sense:
F&R 16"
Front 7.125 wide with a 5 3/8" offset
Rear 9.375 wide with a 9 3/4" offset
So just round up to 7 & 10" wide rims?
Sawyer
Old 11-06-2022, 05:42 PM
F&R 16"
Sawyer
Most likely 7&8s, 10s won't fit under stock SC flares.
Old 11-06-2022, 09:54 PM
had these on my renault r5
Old 11-07-2022, 01:13 PM
Hi Racerbvd, that makes sense. They fit the wheel well clearly inside.
The 1/4 inch spacers are for the rear to ever so slightly clear the trailing arm hardware and still stayed inside.
I'll either just dump the tires or figure out some sort of caliper to measure around the tire. The tires are only good to use as rollers. They look like new but are too old to run on the road.
Jay, a Renault R5 as in the small hatchback from 70s-80s with 13" wheels?
Sawyer911
Old 11-09-2022, 08:36 AM
You can also cut two pieces of straight wood or metal the same size as the rims. Make sure the wood only touches the rims and not the tires.
Put one piece on each side and measure the distance between.
I had the same experience as others with the Gottis that came on my 930
I could hardly give ‘em away.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 11-12-2022, 07:22 AM
