-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   Value of Brembo Front Brake Calipers (http://forums.pelicanparts.com/showthread.php?t=1137845)
stevesc_us 04-07-2023 12:31 PM
Trying to get an idea what this used set of front brake calipers might be worth. They were mounted on my 73 911, but were removed and replaced with front A calipers that are more appropriately sized to my rear M calipers. They are in good shape and were functioning fine when removed.
I also removed a 23mm ATE master cylinder that I also replaced with a smaller 19mm one. Will also be posting what the value of this MS might be as well.
Thanks for your help in valuing these.
http://forums.pelicanparts.com/uploa...1680895807.jpg
juanbenae 04-07-2023 03:35 PM
are those the 944 variant? did you use adapters for them or have the mount holes been hogged out?
they were not worth a ton 10-12 years ago.
stevesc_us 04-07-2023 10:17 PM
Yes I believe they are 944 Turbo calipers. No adapters needed, nor have the mount holes required modification to fit on my 911.
