Value of Brembo Front Brake Calipers
Trying to get an idea what this used set of front brake calipers might be worth. They were mounted on my 73 911, but were removed and replaced with front A calipers that are more appropriately sized to my rear M calipers. They are in good shape and were functioning fine when removed.
I also removed a 23mm ATE master cylinder that I also replaced with a smaller 19mm one. Will also be posting what the value of this MS might be as well.
Thanks for your help in valuing these.
1970 914-6 #2615 (Metallic Green) - SOLD
1974 911 US Carrera Coupe #63 (Lime Green)
1973 911 T Coupe #1891 (Gemini Blue)
Old 04-07-2023, 12:31 PM
Not as it seems
juanbenae's Avatar
are those the 944 variant? did you use adapters for them or have the mount holes been hogged out?
they were not worth a ton 10-12 years ago.
Old 04-07-2023, 03:35 PM
Yes I believe they are 944 Turbo calipers. No adapters needed, nor have the mount holes required modification to fit on my 911.
Old 04-07-2023, 10:17 PM
