What's it worth - '87 3.2L 911 Long Block
Here is what I know about the engine:
1987 911 3.2L Long Block No distributor, exhaust, wires, intake, injectors, DME etc. The motor has 107K and was removed from a cab to build some type of hot rod project. During the project the owner was transfered and had to sell. The motor is owned by a third party who now want to sell as well. It has been sitting for two or three years and turns freely. I do not know if it has Mahle or Kolgenschmidt Pistons & Cylinders. The leakdown on the motor is supposed to be good and the current owner will redo the test with my witness. I was told the leakdown on all cylinders is around 2%. What do you think the stripped long block is worth? Thanks, Eric
Eric PCA Member |
Say around $2500 if has no problem with head studs, rings.
Bernard |
