2.7 Engine minus injection
Looking to pull out and sell my 2.7 complete engine, minus injection system. What might it be worth about? I'm going to sell the webbers seperately.
I can't verify miles on it, and it does leak from a few of the usual places. It was "build and installed" by the PO of the PO which means of course there is no paperwork on it.. :-\ Any ball parks? |
500.00
Platinum Member
Depends on leakdown/compression, Oil pressure & how bad leaks are. Otherwise it's a core.
I'll do a compression test this weekend and bump this topic for updates. Any idea how to get a good oil pressure reading ? The dash gauge always shows plenty of pressure...?
If you can verify that the rebuild took care of the initial problems with the 2.7 (ie. are there time certs installed, is there an eleven blade fan), you may get better than core price but not by much with no history or hard numbers.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
