West Central Ohio 45380
What are these fuchs worth?
6x16 and 7x16
Its been a while.. but I would think no more than $500/set? Tires will be nearly worthless.. and 6x16s are "a dime a dozen".. Figure maybe $250/pr for the 7's, 200/pr for the 6's?
Also consider your location and possible (high) shipping costs to a buyer.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
I concur. $500 with tires. $500 without.
I think it might be worth your time to clean those up a bit. If you have a bead blaster, take the tires off, blast them then repaint. I would guess a good looking set could be worth $750ish, so I wouldn't spend too much time or money on them, but you could get a couple extra hundred with some easy freshening.
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
I'll put in another vote for the $500 range. Not very desired set...
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
Thanks for the input guys, just what I was looking for.
