-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   Value a 77 911s (http://forums.pelicanparts.com/showthread.php?t=598921)
3stewartS 03-24-2011 05:09 PM
Value a 77 911s
I'm looking for a realistic value for my 77 911s sunroof coupe.
I have offered the car for sale here before and got some interest but no offers.
I bought the car as a roller (no engine no trans), bought a 2.7 L on e-bay and a 915 transmission (same seller). I had a time making it run right but after a new gas tank and multiple cleaning of the CIS system it now runs good. Has a puff of smoke at start up but not driving. I repaired some small oil leaks.
The car has been repainted guards red (not the original color) Looks good shines good, but not a flawless paint job. (pics to follow)
I replaced the shifter bushings, rear brake pads, plug wires, air and fuel filters, front A-arm bushings (rubber ones from ER).
The needs/wants include: rear bushings and sway bar (mount is broken), backdated exhaust (still has thermal reactors).
Since the pictures were taken I have polished the fuchs.
http://forums.pelicanparts.com/uploa...1301015081.jpg
more pictures at 911 pictures by 3stewarts - Photobucket
I do really like this car and still may decide not to sell it.
I have recently purchased a 77 targa so I now must decide which to keep
All input is welcome and thanks in advance
3stewartS 03-24-2011 05:16 PM
Ok I just read thread started by "calling911" regarding value for a 76.
sounds like my car is a little better off.
Macroni 03-25-2011 07:54 AM
Value here really depends upon the motor quality.
The car is a non matching number car w/ painted a non original color. If it is a mechaniclly strong performing car it could trade as high as $12,000. less if still in need of sorting.
dienstuhr 03-25-2011 07:54 AM
Nice looking car! Engine swap may reduce value somewhat in terms of uncertainty of mileage - which is what, BTW?
I'd be thinking that a reasonable value may lie in the $10-12K range depending on clean PPI and no other needs.
Cheers
d.
dienstuhr 03-25-2011 07:55 AM
Wow - simultaneous posts - great minds think alike eh Pasta? ;)
Macroni 03-25-2011 07:58 AM
scary....... both VW owners also.........
3stewartS 03-25-2011 09:03 AM
Thanks for all the input. BTW the car shows 114000 on the ODO and it works just fine so I belive it to be accurate.
I understand the engine is the wildcard. If I run compression and leakdown tests and those numbers are respectable, does that help?
What if I pulled the engine. Does the car have any value without the wildcard.
I understand everyones trepidation regarding the 2.7.
Spending 6 grand on an overhaul does not add enough to the value to justify the expense unless I keep and enjoy the car. (which btw is the way I"m leaning) This is a super fun car to drive!
techweenie 03-25-2011 10:03 AM
Mileage is not too relevant since you've swapped drivetrains. Compression & leakdown will go a long way toward setting value. I would not value this car over $8500 not knowing those specs. Red is somewhat out of favor these days and color changes are a negative for many Porschephiles.
3stewartS 04-06-2011 07:01 PM
Well I've decided to focus on the targa. The coupe is For Sale. Thanks again for all the input. I hope to settle somewhere in between.http://forums.pelicanparts.com/uploa...1302145269.jpg
sm70911 04-06-2011 09:49 PM
What was the original color ?
