Value a 77 911s
I'm looking for a realistic value for my 77 911s sunroof coupe.
I have offered the car for sale here before and got some interest but no offers. I bought the car as a roller (no engine no trans), bought a 2.7 L on e-bay and a 915 transmission (same seller). I had a time making it run right but after a new gas tank and multiple cleaning of the CIS system it now runs good. Has a puff of smoke at start up but not driving. I repaired some small oil leaks. The car has been repainted guards red (not the original color) Looks good shines good, but not a flawless paint job. (pics to follow) I replaced the shifter bushings, rear brake pads, plug wires, air and fuel filters, front A-arm bushings (rubber ones from ER). The needs/wants include: rear bushings and sway bar (mount is broken), backdated exhaust (still has thermal reactors). Since the pictures were taken I have polished the fuchs. ![]() more pictures at 911 pictures by 3stewarts - Photobucket I do really like this car and still may decide not to sell it. I have recently purchased a 77 targa so I now must decide which to keep All input is welcome and thanks in advance |
Ok I just read thread started by "calling911" regarding value for a 76.
sounds like my car is a little better off. |
Value here really depends upon the motor quality.
The car is a non matching number car w/ painted a non original color. If it is a mechaniclly strong performing car it could trade as high as $12,000. less if still in need of sorting.
63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S |
Now accepting US $ at par
Nice looking car! Engine swap may reduce value somewhat in terms of uncertainty of mileage - which is what, BTW?
I'd be thinking that a reasonable value may lie in the $10-12K range depending on clean PPI and no other needs. Cheers d.
1985 911 Carrera Coupe 2015 Volkswagen GTI 6-spd some motorcycles |
Wow - simultaneous posts - great minds think alike eh Pasta?
scary....... both VW owners also.........
Thanks for all the input. BTW the car shows 114000 on the ODO and it works just fine so I belive it to be accurate.
I understand the engine is the wildcard. If I run compression and leakdown tests and those numbers are respectable, does that help? What if I pulled the engine. Does the car have any value without the wildcard. I understand everyones trepidation regarding the 2.7. Spending 6 grand on an overhaul does not add enough to the value to justify the expense unless I keep and enjoy the car. (which btw is the way I"m leaning) This is a super fun car to drive! |
Mileage is not too relevant since you've swapped drivetrains. Compression & leakdown will go a long way toward setting value. I would not value this car over $8500 not knowing those specs. Red is somewhat out of favor these days and color changes are a negative for many Porschephiles.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Well I've decided to focus on the targa. The coupe is For Sale. Thanks again for all the input. I hope to settle somewhere in between.
What was the original color ?
